Node Red Plugin fails to start
Hi have updated Node Red 13.3.0 to the latest version Node-RED 13.5.3 running on Home Assistant 2022.11.4,
Post upgrade of NodeRed to 13.5.3, I’m unable to access my configurations in Node-Red. It reports an error that Node-Red is not running. I restart the Node-Red service however it reports the same issue when trying the access the Node-Red configuration, the Node-Red service crashes.
All my automations are done by Node Red, so this is causing major problems to my home automation.
I restore a backup of Node-Red version 13.3.0 and all works correctly, however Node-Red autoupdates to the latest version after a few hours which initiates the same problem and all my automation stops working again.
I would appreciate any assistance regarding this matter.
Log extract:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/00-banner.sh
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 13.5.3
You are running the latest version of this add-on.
System: Home Assistant OS 9.3 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2022.11.4
Home Assistant Supervisor: 2022.11.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/customizations.sh
cont-init: info: /etc/cont-init.d/customizations.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
cont-init: info: running /etc/cont-init.d/node-red.sh
patching file nodes/ui_base.html
Hunk #1 succeeded at 1164 (offset 633 lines).
up to date, audited 9 packages in 1s
found 0 vulnerabilities
cont-init: info: /etc/cont-init.d/node-red.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun nginx (no readiness notification)
services-up: info: copying legacy longrun nodered (no readiness notification)
s6-rc: info: service legacy-services successfully started
[15:23:10] INFO: Starting Node-RED…
start
node $NODE_OPTIONS node_modules/node-red/red.js “–settings” “/etc/node-red/config.js”
30 Nov 15:23:14 - [info]
Welcome to Node-RED
30 Nov 15:23:14 - [info] Node-RED version: v3.0.2
30 Nov 15:23:14 - [info] Node.js version: v16.17.1
30 Nov 15:23:14 - [info] Linux 5.15.61-v8 arm64 LE
30 Nov 15:23:16 - [info] Loading palette nodes
30 Nov 15:23:21 - [info] Dashboard version 3.2.0 started at /endpoint/ui
30 Nov 15:23:22 - [info] Settings file : /etc/node-red/config.js
30 Nov 15:23:22 - [info] Context store : ‘default’ [module=memory]
30 Nov 15:23:22 - [info] User directory : /config/node-red/
30 Nov 15:23:22 - [warn] Projects disabled : editorTheme.projects.enabled=false
30 Nov 15:23:22 - [info] Flows file : /config/node-red/flows.json
30 Nov 15:23:22 - [info] Server now running at http://127.0.0.1:46836/
30 Nov 15:23:22 - [info] Starting flows
[15:23:22] INFO: Starting NGinx…
30 Nov 15:23:23 - [error] [api-call-service:aeafaa54a5aad308] Error: Server config node not found
30 Nov 15:23:23 - [info] Started flows
30 Nov 15:23:23 - [info] [server:Home Assistant] Connecting to http://localhost:8123
30 Nov 15:23:23 - [red] Uncaught Exception:
30 Nov 15:23:23 - [error] Error: Invalid access token for websocket
at /opt/node_modules/node-red-contrib-home-assistant-websocket/dist/homeAssistant/Websocket.js:112:29
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at Websocket.connect (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/homeAssistant/Websocket.js:82:23)
[15:23:23] WARNING: Node-RED crashed, halting add-on
[15:23:23] INFO: Node-RED stopped, restarting…
s6-rc: info: service legacy-services: stopping
s6-svwait: fatal: supervisor died
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Select an HA node and export it. Does the server config contain a property addon? If not edit the HA server config and deploy it, then check again.
