Node-Red redeploy triggers unwanted events
Hi all,
I have a simple flow to control my covers with a switch.
Basically this works perfect.
But when I redeploy the flows a state_change message is triggered.
Is there a way to block this initial event?
I read a lot about that in the forum but didn’t find a suitable solution.
In general I would like to have this flow stateless and should be triggered every time I really press a button. Reason is - I can stop the covers moving by sending the same value a second time. If I limit this to a real state-change this doesn’t work anymore.
Any ideas? Probably there is a counter node where I can reset the counter to zero at certain events and let messages pass after x received messages?
