Maybe it is the typical error of just installing the integration in HACS, which just adds the integration to the HA integration list.
It is then required to actually install the integration in HA itself also.
It is an error newbies make and also experienced users that have not added integrations from HACS in a while.
What a simple thing solved after hours of research !
Many thanks !!!
And yes I’m a totally newbee in HA and Node RED and Rest API …
Then with you i’m able to get a new sensor into HA!
Hello, I have the same issue. Would you so kind and describe how You dit it in HA;
I dont understand instruction on Github -
In the Home Assistant UI go to “Configuration” → “Integrations” click “+” and search for “Node-RED”
Many thanks
