node-RED: Setting the volume level based on existing volume level
Hi all!
I am trying to program my HUE Dimmer Switch to control Sonos.
I have successfully manage to turn on my Sonos and adjusting the volume, but I am trying to increase the volume_set steps.
I’m able to fetch the existing volume level and I’d like to add 0.05 to the value but I am getting “Extra keys not allowed”.
Please help me with what is wrong with the following statement entered in the DATA field:
{"volume_level":{{{data.attributes.volume_level}- 0.1}}}
Have a great day everyone!
Change the type of the data field to JSONata Expression and use
{"volume_level": data.attributes.volume_level - 0.1}
Thank you Kermit,
But i still get the same error:
Need to change the type of the data field
This worked!!! Thank you sooooooooo much!!!
(It turned out I was increasing the value too much as well…)
But, what is the difference between JSON and EXPRESSION?
I just found this. I copiesd the code you wrote, changed to “Expression” but get API Error:
78 / 5000
Rezultatele traducerii
How can I make the volume of a speaker take the value of an input number?
{“volume_level”:states.input_number.volume.state }
https://zachowj.github.io/node-red-contrib-home-assistant-websocket/guide/call-service.html#doing-arithmetic
{"volume_level":  $number($entities("input_number.volume").state) }
It works.
Thank you very much!
Have a nice day and weekend!
what is here the right code for volume up?
{"volume_level": $number($entities("input_number.volume").state) +0.1}
my entity id: media_player.denon_partyraum
have it
{ "volume_level":  $number($entities("media_player.denon_partyraum").attributes.volume_level)  -0.05}
I have exact same problem, maybe u figured it out ?
