Node-Red showing errors every few seconds in Mosquitto Broker log
Not even sure this is a problem but it doesn’t feel right.
I’m using everything through HA as integrations.
Every few seconds I get errors as shown below in the Mosquitto Broker log:
2024-02-25 23:17:09: Client NodeRed-869861a20ffa24cc-lnedf disconnected, not authorised.
2024-02-25 23:17:10: New connection from 192.168.1.128:49734 on port 1883.
error: received null username or password for unpwd check
2024-02-25 23:17:10: Client NodeRed-869861a20ffa24cc-lnedf disconnected, not authorised.
2024-02-25 23:17:11: New connection from 192.168.1.128:49746 on port 1883.
2024-02-25 23:17:11: Client NodeRed-869861a20ffa24cc-lnedf disconnected, not authorised.
2024-02-25 23:17:12: New connection from 192.168.1.128:49762 on port 1883.
I assume Mosquitto is not happy with the login credentials supplied by NR ? But the strange thing is; everything seems to work in my NR flows. I can get data from and send messages to my Zigbee devices and they all react perfectly.
I have been checking over error logs system-wide just as a house keeping exercise when I came across these errors.
Anyone have a clue what might be going on and how I might fix it ?
TIA
Go to the info tab where the debug is, the “I” button enter that number in the search. Double click the node and check it’s configuration.
You sir are a veritable genius !
Sorted !
There was no username or password set on that node.
Thanks a million.
