I am creating a new document in an ERP software by using the POST request and REST API. This has successfully worked when I am running Node-RED separately (not under home assistant).
However, when I try to run the same sequence in Node-RED running under home assistant it shows me an error message: “Error: connect ECONNREFUSED 0.0.0.0:8000”
The ERP software is locally hosted under: 0.0.0.0:8000
My function node:
I am able to access the msg.url in the function node so I do not know what the issue is here.
Any help would be much appreciated.
Thanks in advance
