I have a NR flow in Home Assistant, its triggered by the outside LUX level and turns on our living room lights at a certain colour temperature - different for AM and PM.
It seems to miss the variable reading functions and turns them on at the last used setting instead, not every time though?
Thats what i thought, i have changed to the one-line version as it is a little easier to read.
Can’t think of any way that the function can be ignored or skipped though, but it does happen. I do know that the bulbs used will turn on in the state last used if no other controlling factors appear, but the command uses the colour temp command to set the tone.
It still randomly just turns the lights on and misses the colour/brightness data part of the message - this results in the lights turning on at their previous state instead.
