Everything is set up, but when click in the left bar on “Node-RED”, I get a pop up mentioning “The add-on is not running. Do you want to start it now?”. I choose “Start Add-on”, and after some seconds (between 10 and 15 seconds), the same message appears.
I tried to look into the logs (logbook), but nothing is mentioned there.
Look in the logs under the addon “Settings > Addons > Node Red”. You should see something like this:
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 14.6.1
There is an update available for this add-on!
Latest add-on version: 14.6.3
Please consider upgrading as soon as possible.
System: Home Assistant OS 11.0 (amd64 / qemux86-64)
Home Assistant Core: 2023.10.3
Home Assistant Supervisor: 2023.10.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
