pete.AUS
(Pete)
1
Hi all,
I am running Node Red via the HA Addon and when opening flows I cannot see any of the sensor states.
I know the flow is running as my inverters are responding to home load changes.
I have also tried re adding the Node red companion intergration with no success
(pre check conditions group should show states below the nodes)
Anyone had this issue before?
pete.AUS
(Pete)
2
Update looks like its a known issue
Mikefila
(Mike Fila)
3
Have you tried using your home assistant ip with 1880
instead of 8123
