Hello
few days ago node red stop working, I have try to reinstall it, reinstall old backup,then completly delete node red folder and install fresh node red, it just will not start.
log
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 14.2.0
You are running the latest version of this add-on.
System: Home Assistant OS 10.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.5.3
Home Assistant Supervisor: 2023.04.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
[20:12:16] INFO: Starting Node-RED...
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
19 May 20:12:19 - [info]
Welcome to Node-RED
19 May 20:12:19 - [info] Node-RED version: v3.0.2
19 May 20:12:19 - [info] Node.js version: v18.16.0
19 May 20:12:19 - [info] Linux 6.1.21-v8 arm64 LE
19 May 20:12:21 - [info] Loading palette nodes
19 May 20:12:25 - [info] Dashboard version 3.4.0 started at /endpoint/ui
19 May 20:12:26 - [info] Settings file : /etc/node-red/config.js
19 May 20:12:26 - [info] Context store : 'default' [module=memory]
19 May 20:12:26 - [info] User directory : /config/node-red/
19 May 20:12:26 - [warn] Projects disabled : editorTheme.projects.enabled=false
19 May 20:12:26 - [info] Flows file : /config/node-red/flows.json
19 May 20:12:26 - [warn] Encrypted credentials not found
19 May 20:12:26 - [info] Server now running at http://127.0.0.1:46836/
19 May 20:12:26 - [info] Starting flows
19 May 20:12:26 - [info] Started flows
[20:12:26] INFO: Starting NGinx...
19 May 20:12:31 - [info] [server:Home Assistant] Connecting to http://supervisor/core
19 May 20:12:31 - [info] [server:Home Assistant] Connected to http://supervisor/core
