Node Red stops loading nodes
Hi, after I updated the KNX Ultimate Node it still seems to work but I can´t access the Dashboard, it stops with “Loading Nodes 78/150”. The Protocol is just black an green, nothing special, nothing red. Can anybody see what the problem is and how I can fix it?
Protocol:
5 Nov 13:06:08 - [warn] Projects disabled : editorTheme.projects.enabled=false
5 Nov 13:06:08 - [info] Flows file     : /config/node-red/flows.json
5 Nov 13:06:08 - [info] Server now running at http://127.0.0.1:46836/
[13:06:08] INFO: Starting NGinx...
5 Nov 13:06:08 - [info] Starting flows
5 Nov 13:06:08 - [info] KNX-Unsecure: connection to insecure interface/router using node KNX Gateway
5 Nov 13:06:08 - [info] ttsultimate-config 3a64f2c7e125fb87: Autodiscover current IP 192.168.0.38
5 Nov 13:06:08 - [info] ttsultimate-config 3a64f2c7e125fb87: TTS cache set to /config/node-red/sonospollyttsstorage/ttsfiles
5 Nov 13:06:08 - [info] ttsultimate-config 3a64f2c7e125fb87: google credentials path set to /config/node-red/sonospollyttsstorage/ttsultimategooglecredentials
5 Nov 13:06:08 - [info] ttsultimate-config 3a64f2c7e125fb87: hailing path set to /config/node-red/sonospollyttsstorage/hailingpermanentfiles
5 Nov 13:06:08 - [info] ttsultimate-config 3a64f2c7e125fb87: permanent files path set to /config/node-red/sonospollyttsstorage/ttspermanentfiles
5 Nov 13:06:08 - [info] ttsultimate-config 3a64f2c7e125fb87: Node-Red node.js Endpoint will be created here: http://192.168.0.38:1980/tts
5 Nov 13:06:08 - [info] Started flows
5 Nov 13:06:08 - [info] [server:Home Assistant] Connecting to http://192.168.0.38:8123
5 Nov 13:06:08 - [info] [mqtt-broker:MQTT Broker auf Home Assistant] Connected to broker: mqtt://192.168.0.38:1883
5 Nov 13:06:08 - [info] ttsultimate: ZONE COORDINATOR "Soundbar"
5 Nov 13:06:09 - [info] ttsultimate: ZONE COORDINATOR "Soundbar"
5 Nov 13:06:09 - [info] [alexa-remote-account:4e827432ec4e30bd] intialising with the PROXY method and saved data...
5 Nov 13:06:09 - [info] [server:Home Assistant] Connected to http://192.168.0.38:8123
'notification update already running...'
'notification update apply but we are already up to date: UPDATE 0653b2c9-e889-3694-a27a-d250e0c9a1d2 @ 3'
'notification update ended successfully...'
5 Nov 13:16:52 - [error] [api-call-service:WLED Garagentore Preset] Call-service error. Option Tor links auf not valid for select.wled_playlist
5 Nov 13:17:24 - [error] [api-call-service:WLED Garagentore Preset] Call-service error. Option Tor links zu not valid for select.wled_playlist
5 Nov 13:48:45 - [info] ttsultimate: Hailing disabled
'notification update apply but we are already up to date: UPDATE ba40aeb1-3c8a-3dac-9570-7e1d5615a127 @ 3'
5 Nov 15:15:29 - [info] ttsultimate: Hailing disabled
'notification update apply but we are already up to date: UPDATE e269ee59-2ff1-3269-a8e7-237e3e5010bc @ 3'
5 Nov 17:58:25 - [error] [api-call-service:WLED Garagentore Wiedergabeliste] Call-service error. Option Bewegungsmelder not valid for select.wled_preset
5 Nov 17:59:19 - [error] [api-call-service:WLED Garagentore Preset] Call-service error. Option Tor rechts auf not valid for select.wled_playlist
5 Nov 17:59:19 - [info] ttsultimate: Hailing .MP3, skip tts, filename: Hailing_Hailing.mp3
5 Nov 17:59:31 - [error] [api-call-service:WLED Garagentore Preset] Call-service error. Option Tor rechts zu not valid for select.wled_playlist
5 Nov 18:01:59 - [error] [api-call-service:WLED Garagentore Preset] Call-service error. Option Tor links auf not valid for select.wled_playlist
5 Nov 18:02:07 - [error] [api-call-service:WLED Garagentore Wiedergabeliste] Call-service error. Option Bewegungsmelder not valid for select.wled_preset
5 Nov 18:03:37 - [error] [api-call-service:WLED Garagentore Preset] Call-service error. Option Tor links zu not valid for select.wled_playlist
5 Nov 20:18:00 - [error] [api-call-service:WLED Garagentore Wiedergabeliste] Call-service error. Option Bewegungsmelder not valid for select.wled_preset
'notification update apply but we are already up to date: UPDATE 3e9f8f52-a05a-3667-994e-7f76967fceea @ 98'
5 Nov 22:06:23 - [error] [api-call-service:WLED Garagentore Preset] Call-service error. Option Tor links auf not valid for select.wled_playlist
5 Nov 22:07:05 - [error] [api-call-service:WLED Garagentore Wiedergabeliste] Call-service error. Option Bewegungsmelder not valid for select.wled_preset
5 Nov 22:07:31 - [error] [api-call-service:WLED Garagentore Preset] Call-service error. Option Tor links zu not valid for select.wled_playlist
'notification update apply but we are already up to date: UPDATE a5a4fe5b-2221-3305-9aad-3452c700df5c @ 277'
5 Nov 22:26:09 - [info] [server:Home Assistant] Connection closed to http://192.168.0.38:8123
5 Nov 22:26:09 - [info] [server:Home Assistant] Connecting to http://192.168.0.38:8123
5 Nov 22:26:14 - [info] [server:Home Assistant] Connecting to http://192.168.0.38:8123
5 Nov 22:26:19 - [info] [server:Home Assistant] Connecting to http://192.168.0.38:8123
5 Nov 22:26:24 - [info] [server:Home Assistant] Connecting to http://192.168.0.38:8123
5 Nov 22:26:24 - [info] [server:Home Assistant] Connected to http://192.168.0.38:8123
Is there anybody who can help me fixing this problem? I have a backup, but does it solve the problem?
Doesn’t look like a lot of people have seen this. Just ran into the same after I updated a couple of nodes in the pallette manager, and no log entries which are relevant.
Fortunately I took a snapshot of the VM before the upgrade so for me only option is to roll back and then upgrade the nodes one by one until I run into the culprit which is causing it…
