Try this to watch your CPU and other stuff using the Node Red Dasboard.
It uses node-red-contrib-cpu.
[{"id":"cb7fc596.828808","type":"inject","z":"e0191037.0d5e2","name":"","topic":"","payload":"","payloadType":"date","repeat":"20","crontab":"","once":true,"onceDelay":"2","x":210,"y":520,"wires":[["71e70f3f.e26bb","bac7334c.9f787","a39abdda.39e1c"]]},{"id":"a39abdda.39e1c","type":"exec","z":"e0191037.0d5e2","command":"cat /sys/class/thermal/thermal_zone0/temp","addpay":false,"append":"","useSpawn":"","timer":"","oldrc":false,"name":"getCPUtemp","x":470,"y":520,"wires":[["53b35b21.17d1a4"],[],[]]},{"id":"71e70f3f.e26bb","type":"exec","z":"e0191037.0d5e2","command":"free | grep Mem | awk '{print 100*($4+$6+$7)/$2}'","addpay":false,"append":"","useSpawn":"","timer":"","name":"Free Memory","x":470,"y":680,"wires":[["8bf140e5.f3d4d"],[],[]]},{"id":"bd2f6218.d1bdb","type":"exec","z":"e0191037.0d5e2","command":"df -h","addpay":false,"append":"","useSpawn":"","timer":"","name":"Disk Usage","x":470,"y":760,"wires":[["6faa176a.2a10e8"],[],[]]},{"id":"dc904cdf.e74ff","type":"inject","z":"e0191037.0d5e2","name":"","topic":"","payload":"","payloadType":"date","repeat":"60","crontab":"","once":false,"x":210,"y":760,"wires":[["bd2f6218.d1bdb"]]},{"id":"8bf140e5.f3d4d","type":"function","z":"e0191037.0d5e2","name":"String To Number","func":"var originalval = msg.payload;\nvar newval = \"\";\nnewval = parseFloat(originalval).toFixed(0)-0;\nmsg.payload = newval;\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":680,"wires":[["d92f2bce.934a58"]]},{"id":"d92f2bce.934a58","type":"ui_gauge","z":"e0191037.0d5e2","name":"Memory","group":"70d09e69.50051","order":4,"width":0,"height":0,"gtype":"gage","title":"Memory","label":"RAM","format":"{{value}}","min":0,"max":"500","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":860,"y":680,"wires":[]},{"id":"fdd8ad53.fbb3","type":"ui_gauge","z":"e0191037.0d5e2","name":"","group":"70d09e69.50051","order":5,"width":0,"height":0,"gtype":"gage","title":"Disk","label":"Usage","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":850,"y":760,"wires":[]},{"id":"6faa176a.2a10e8","type":"function","z":"e0191037.0d5e2","name":"function","func":"var re = /([0-9]{2})%/\nvar idx = msg.payload.search(re);\nvar str = msg.payload;\nif (idx >=0) {\n str = msg.payload.substring(idx, idx + 2);\n}\nmsg.payload = str;\nreturn msg;","outputs":1,"noerr":0,"x":680,"y":760,"wires":[["fdd8ad53.fbb3"]]},{"id":"b164f679.624058","type":"ui_gauge","z":"e0191037.0d5e2","name":"","group":"70d09e69.50051","order":3,"width":0,"height":0,"gtype":"gage","title":"Processor","label":"CPU","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":860,"y":600,"wires":[]},{"id":"a0e41fb2.2e23f","type":"ui_chart","z":"e0191037.0d5e2","name":"CPU Temp","group":"70d09e69.50051","order":2,"width":0,"height":0,"label":"CPU Temp","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":true,"ymin":"40","ymax":"60","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":true,"x":870,"y":520,"wires":[[],[]]},{"id":"8673cec9.24457","type":"ui_gauge","z":"e0191037.0d5e2","name":"","group":"70d09e69.50051","order":1,"width":0,"height":0,"gtype":"gage","title":"CPU Temperature","label":"C","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":890,"y":480,"wires":[]},{"id":"53b35b21.17d1a4","type":"function","z":"e0191037.0d5e2","name":"Payload /1000","func":"str = msg.payload\nmsg.payload = str/1000;\nreturn msg;","outputs":1,"noerr":0,"x":660,"y":500,"wires":[["8673cec9.24457","a0e41fb2.2e23f"]]},{"id":"bac7334c.9f787","type":"cpu","z":"e0191037.0d5e2","name":"","msgCore":true,"msgOverall":false,"x":470,"y":600,"wires":[["b164f679.624058"]]},{"id":"70d09e69.50051","type":"ui_group","z":"","name":"NUC","tab":"6f60567.936e0a8","order":1,"disp":true,"width":"6","collapse":false},{"id":"6f60567.936e0a8","type":"ui_tab","z":"","name":"NUC","icon":"dashboard"}]
