Did not update anything on HA or Node red side. MY automation stopped working. I cant get node red to start succesfully again. Even after going back a few days to a working save (but again, I havent updated in a week so nothing should have changed anyway)
I took out the g++ line in my configuration and it loaded fine, but confused as to why its causing problems now.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 9.1.3
You are running the latest version of this add-on.
System: Home Assistant OS 6.0 (aarch64 / odroid-n2)
Home Assistant Core: 2021.6.3
[cont-init.d] 00-banner.sh: exited 0.
Home Assistant Supervisor: 2021.06.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] customizations.sh: executing...
fetch https://dl-cdn.alpinelinux.org/alpine/v3.13/main/aarch64/APKINDEX.tar.gz
fetch https://dl-cdn.alpinelinux.org/alpine/v3.13/community/aarch64/APKINDEX.tar.gz
v3.13.5-194-g1274644b64 [https://dl-cdn.alpinelinux.org/alpine/v3.13/main]
v3.13.5-187-g1477654ee3 [https://dl-cdn.alpinelinux.org/alpine/v3.13/community]
OK: 13742 distinct packages available
(1/1) Installing make (4.3-r0)
Executing busybox-1.32.1-r5.trigger
OK: 140 MiB in 47 packages
ERROR: unable to select packages:
musl-1.2.2-r0:
breaks: musl-dev-1.2.2-r1[musl=1.2.2-r1]
satisfies: world[musl=1.2.2-r0]
apk-tools-2.12.4-r0[musl>=1.2]
apk-tools-2.12.4-r0[so:libc.musl-aarch64.so.1]
nginx-1.18.0-r13[so:libc.musl-aarch64.so.1]
gcc-10.2.1_pre1-r3[so:libc.musl-aarch64.so.1]
g++-10.2.1_pre1-r3[so:libc.musl-aarch64.so.1]
tzdata-2021a-r0[so:libc.musl-aarch64.so.1]
patch-2.7.6-r6[so:libc.musl-aarch64.so.1]
bash-5.1.0-r0[so:libc.musl-aarch64.so.1]
ca-certificates-20191127-r5[so:libc.musl-aarch64.so.1]
python3-3.8.10-r0[so:libc.musl-aarch64.so.1]
binutils-2.35.2-r1[so:libc.musl-aarch64.so.1]
busybox-1.32.1-r5[so:libc.musl-aarch64.so.1]
libffi-3.3-r2[so:libc.musl-aarch64.so.1]
openssh-client-8.4_p1-r3[so:libc.musl-aarch64.so.1]
sqlite-libs-3.34.1-r0[so:libc.musl-aarch64.so.1]
curl-7.76.1-r0[so:libc.musl-aarch64.so.1]
ncurses-libs-6.2_p20210109-r0[so:libc.musl-aarch64.so.1]
expat-2.2.10-r1[so:libc.musl-aarch64.so.1]
git-2.30.2-r0[so:libc.musl-aarch64.so.1]
musl-utils-1.2.2-r0[so:libc.musl-aarch64.so.1]
nghttp2-libs-1.42.0-r1[so:libc.musl-aarch64.so.1]
nodejs-14.16.1-r1[so:libc.musl-aarch64.so.1]
gdbm-1.19-r0[so:libc.musl-aarch64.so.1]
libstdc++-10.2.1_pre1-r3[so:libc.musl-aarch64.so.1]
libbz2-1.0.8-r1[so:libc.musl-aarch64.so.1]
brotli-libs-1.0.9-r3[so:libc.musl-aarch64.so.1]
libcurl-7.76.1-r0[so:libc.musl-aarch64.so.1]
mpc1-1.2.0-r0[so:libc.musl-aarch64.so.1]
libgphobos-10.2.1_pre1-r3[so:libc.musl-aarch64.so.1]
pcre-8.44-r0[so:libc.musl-aarch64.so.1]
oniguruma-6.9.6-r0[so:libc.musl-aarch64.so.1]
mpfr4-4.1.0-r0[so:libc.musl-aarch64.so.1]
zlib-1.2.11-r3[so:libc.musl-aarch64.so.1]
libgomp-10.2.1_pre1-r3[so:libc.musl-aarch64.so.1]
readline-8.1.0-r0[so:libc.musl-aarch64.so.1]
make-4.3-r0[so:libc.musl-aarch64.so.1]
libedit-20191231.3.1-r1[so:libc.musl-aarch64.so.1]
libgcc-10.2.1_pre1-r3[so:libc.musl-aarch64.so.1]
libssl1.1-1.1.1k-r0[so:libc.musl-aarch64.so.1]
alpine-baselayout-3.2.0-r8[so:libc.musl-aarch64.so.1]
libcrypto1.1-1.1.1k-r0[so:libc.musl-aarch64.so.1]
libatomic-10.2.1_pre1-r3[so:libc.musl-aarch64.so.1]
xz-libs-5.2.5-r0[so:libc.musl-aarch64.so.1]
openssh-keygen-8.4_p1-r3[so:libc.musl-aarch64.so.1]
pcre2-10.36-r0[so:libc.musl-aarch64.so.1]
c-ares-1.17.1-r1[so:libc.musl-aarch64.so.1]
scanelf-1.2.8-r0[so:libc.musl-aarch64.so.1]
gmp-6.2.1-r0[so:libc.musl-aarch64.so.1]
jq-1.6-r1[so:libc.musl-aarch64.so.1]
isl22-0.22-r0[so:libc.musl-aarch64.so.1]
[21:25:21] FATAL: Failed installing system package g++
[cont-init.d] customizations.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
