Hi all,
I have had node-red up and running for ages with no issues. All of sudden it has stopped working for me.
Hoping someone can help out.
Many Thanks.
Here are the node red logs.
e[34m or support in, e.g., GitHub, forums or the Discord chat.e[0m
e[34m-----------------------------------------------------------e[0m
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nginx successfully started
up to date, audited 655 packages in 7s
52 packages are looking for funding
run npm fund
for details
45 vulnerabilities (2 low, 17 moderate, 18 high, 8 critical)
To address issues that do not require attention, run:
npm audit fix
To address all issues possible (including breaking changes), run:
npm audit fix --force
Some issues need review, and may require choosing
a different dependency.
Run npm audit
for details.
npm notice
npm notice New minor version of npm available! 10.7.0 → 10.8.3
npm notice Changelog: Release v10.8.3 · npm/cli · GitHub
npm notice To update run: npm install -g [email protected]
npm notice
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[20:44:49] INFO: e[32mStarting Node-RED…e[0m
start
node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
5 Sep 20:44:50 - [info]
Welcome to Node-RED
5 Sep 20:44:50 - [info] Node-RED version: v4.0.2
5 Sep 20:44:50 - [info] Node.js version: v18.20.3
5 Sep 20:44:50 - [info] Linux 6.6.46-haos x64 LE
5 Sep 20:44:51 - [info] Loading palette nodes
5 Sep 20:44:51 - [info] Node-RED Contrib Theme Collection version: v4.0.8
5 Sep 20:44:56 - [info] Dashboard version 3.6.5 started at /endpoint/ui
5 Sep 20:44:56 - [info] Settings file : /etc/node-red/config.js
5 Sep 20:44:56 - [info] Context store : ‘default’ [module=memory]
5 Sep 20:44:56 - [info] User directory : /config/
5 Sep 20:44:56 - [warn] Projects disabled : editorTheme.projects.enabled=false
5 Sep 20:44:56 - [info] Flows file : /config/flows.json
5 Sep 20:44:56 - [info] Server now running at http://127.0.0.1:46836/
5 Sep 20:44:57 - [info] Starting flows
fileServer listening on ip 192.168.0.13 and port 8098
[20:44:57] INFO: e[32mStarting NGinx…e[0m
5 Sep 20:44:57 - [info] [wled:1b1cabb698f8b240] wled 192.168.20.11
5 Sep 20:44:57 - [info] Started flows
5 Sep 20:44:57 - [red] Uncaught Exception:
5 Sep 20:44:57 - [error] TypeError: Cannot convert undefined or null to object
at Function.values ()
at Timeout._onTimeout (/config/node_modules/node-red-contrib-things/red/trigger.js:102:29)
at listOnTimeout (node:internal/timers:569:17)
at processTimers (node:internal/timers:512:7)
[20:44:57] INFO: e[32mService Node-RED exited with code 1 (by signal 0)e[0m
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[20:44:57] INFO: e[32mService NGINX exited with code 0 (by signal 0)e[0m
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
LOGS FROM SUPERVISOR
2024-09-05 20:42:02.675 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Node-RED is failed, restarting…
2024-09-05 20:42:02.680 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_a0d7b954_nodered application
2024-09-05 20:42:03.035 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on Package node-red/amd64 · GitHub with version 18.0.5
2024-09-05 20:42:20.366 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Node-RED is failed, restarting…
2024-09-05 20:42:20.372 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_a0d7b954_nodered application
2024-09-05 20:42:20.749 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on Package node-red/amd64 · GitHub with version 18.0.5
2024-09-05 20:42:38.255 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Node-RED is failed, restarting…
2024-09-05 20:42:38.260 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_a0d7b954_nodered application
2024-09-05 20:42:38.617 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on Package node-red/amd64 · GitHub with version 18.0.5
2024-09-05 20:42:57.607 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Node-RED is failed, restarting…
2024-09-05 20:42:57.612 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_a0d7b954_nodered application
2024-09-05 20:42:58.000 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on Package node-red/amd64 · GitHub with version 18.0.5
