I did something similar with my hue scenes. I wanted to switch between several scenes via one button press. It works quite well. This is the logic behind:
[{"id":"e434b96a.a42998","type":"api-call-service","z":"d4113bbe.91f4a8","name":"Arctic Aurora","version":1,"debugenabled":false,"service_domain":"hue","service":"hue_activate_scene","entityId":"","data":"{\"group_name\":\"Wohnzimmer\",\"scene_name\":\"Nordlichter\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1190,"y":1940,"wires":[[]]},{"id":"f79774f7.10fe88","type":"switch","z":"d4113bbe.91f4a8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"arrow_left_click","vt":"str"},{"t":"eq","v":"arrow_right_click","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":330,"y":1860,"wires":[["8d01418c.754b1"],["dfa79123.a9f72"]]},{"id":"bca55557.e11808","type":"comment","z":"d4113bbe.91f4a8","name":"Scene Select","info":"","x":350,"y":1820,"wires":[]},{"id":"1a42fea3.c7b261","type":"counter","z":"d4113bbe.91f4a8","name":"","init":"1","step":"1","lower":"1","upper":"6","mode":"increment","outputs":2,"x":720,"y":1860,"wires":[["8a397758.c8e178","be6605d8.332c78","3db219ba.67ce76"],[]]},{"id":"ff12353.1dc67c8","type":"inject","z":"d4113bbe.91f4a8","name":"Left","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"msg.payload","payload":"true","payloadType":"bool","x":330,"y":1900,"wires":[["8d01418c.754b1"]]},{"id":"5dbe5890.bd6118","type":"inject","z":"d4113bbe.91f4a8","name":"Right","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"msg.payload","payload":"true","payloadType":"bool","x":330,"y":1940,"wires":[["dfa79123.a9f72"]]},{"id":"dfa79123.a9f72","type":"change","z":"d4113bbe.91f4a8","name":"","rules":[{"t":"set","p":"increment","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":1900,"wires":[["1a42fea3.c7b261"]]},{"id":"8a397758.c8e178","type":"switch","z":"d4113bbe.91f4a8","name":"Upper","property":"countUpperLimitReached","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":850,"y":1860,"wires":[["9ed7df9e.69344"]]},{"id":"be6605d8.332c78","type":"switch","z":"d4113bbe.91f4a8","name":"Lower","property":"countLowerLimitReached","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":850,"y":1900,"wires":[["f667c6aa.0e3a68"]]},{"id":"c000cfe8.ff4df","type":"change","z":"d4113bbe.91f4a8","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1140,"y":1860,"wires":[["1a42fea3.c7b261"]]},{"id":"8b008deb.41f11","type":"change","z":"d4113bbe.91f4a8","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"6","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1140,"y":1900,"wires":[["1a42fea3.c7b261"]]},{"id":"8d01418c.754b1","type":"change","z":"d4113bbe.91f4a8","name":"","rules":[{"t":"set","p":"decrement","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":1860,"wires":[["1a42fea3.c7b261"]]},{"id":"6c61e8d5.53ed38","type":"switch","z":"d4113bbe.91f4a8","name":"Value","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"5","vt":"num"},{"t":"eq","v":"6","vt":"num"}],"checkall":"true","repair":false,"outputs":6,"x":990,"y":1980,"wires":[["e434b96a.a42998"],["b85e16a4.5f0978"],["918f78a4.6277b8"],["782b0db9.1694c4"],["1c3216e9.e84559"],["d1949ca.6d76f6"]]},{"id":"3db219ba.67ce76","type":"rbe","z":"d4113bbe.91f4a8","name":"","func":"rbe","gap":"1%","start":"","inout":"out","property":"payload","x":850,"y":1940,"wires":[["6c61e8d5.53ed38"]]},{"id":"9ed7df9e.69344","type":"delay","z":"d4113bbe.91f4a8","name":"5ms","pauseType":"delay","timeout":"5","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":990,"y":1860,"wires":[["c000cfe8.ff4df"]]},{"id":"f667c6aa.0e3a68","type":"delay","z":"d4113bbe.91f4a8","name":"5ms","pauseType":"delay","timeout":"5","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":990,"y":1900,"wires":[["8b008deb.41f11"]]},{"id":"1c3216e9.e84559","type":"api-call-service","z":"d4113bbe.91f4a8","name":"Abend Stimmung","version":1,"debugenabled":false,"service_domain":"hue","service":"hue_activate_scene","entityId":"","data":"{\"group_name\":\"Wohnzimmer\",\"scene_name\":\"Abend Stimmung\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1210,"y":2180,"wires":[[]]},{"id":"b85e16a4.5f0978","type":"api-call-service","z":"d4113bbe.91f4a8","name":"Concentrate","version":1,"debugenabled":false,"service_domain":"hue","service":"hue_activate_scene","entityId":"","data":"{\"group_name\":\"Wohnzimmer\",\"scene_name\":\"Konzentrieren\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1190,"y":2000,"wires":[[]]},{"id":"782b0db9.1694c4","type":"api-call-service","z":"d4113bbe.91f4a8","name":"Relax","version":1,"debugenabled":false,"service_domain":"hue","service":"hue_activate_scene","entityId":"","data":"{\"group_name\":\"Wohnzimmer\",\"scene_name\":\"Entspannen\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1170,"y":2120,"wires":[[]]},{"id":"918f78a4.6277b8","type":"api-call-service","z":"d4113bbe.91f4a8","name":"Dim","version":1,"debugenabled":false,"service_domain":"hue","service":"hue_activate_scene","entityId":"","data":"{\"group_name\":\"Wohnzimmer\",\"scene_name\":\"Gedimmt\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1170,"y":2060,"wires":[[]]},{"id":"d1949ca.6d76f6","type":"api-call-service","z":"d4113bbe.91f4a8","name":"Bright","version":1,"debugenabled":false,"service_domain":"hue","service":"hue_activate_scene","entityId":"","data":"{\"group_name\":\"Wohnzimmer\",\"scene_name\":\"Hell\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1170,"y":2240,"wires":[[]]}]
What it does: Basically its just a counter that with each press counts up/down until it reaches the upper / lower limit and then resets. Then I just aligned the different scenes to the values of the counter and with that I am able to basically switch around the scenes in a carousel.
