Node Red Time Based Conditional Flow
I’ve created an automation within home assistant, but want to get it shifted over to NR. In principle the above is I think what I want to do(tested parts but not as whole), but I feel like there has to be a better way to do these types of things. I have quite a few that I’m trying to move over from HA that are more time based triggers with conditions for certain days/items. Is it better to split them into a single rung for what to do?
Thanks in advance for any advice or suggestions.
For my time-based automations, I use the times of the day sensors and workday sensor.
Then, I use event:state change nodes to trigger various actions based upon the time of the day and day of the week.
Thank you for reply, that’s an interesting idea. I hadn’t seen the TOD sensor but frequently use the Workday sensor for various other automation. I’ll have to set this up and give it a try. Thanks again.
