Ever since I updated my node-red container to node v10, and updated my palettes, all my time based automations in Node-Red are off by 2 hours.
I have - /etc/localtime:/etc/localtime:ro
bind mounted in both HA and NR containers, both containers see the correct timezone, and date/time.
I typically use Schedex
nodes for time triggered things, but it doesn’t matter what time based nodes I use, they are all off by 2 hours.
For instance, I use a time-range-switch
node for a few automation flows, that say “if time is within this range, do this”…they are off by 2 hours.
Bigtimer, schedex, time-range-switch, all act like they are 2 hours behind (all are set to my lat/lon in the config also)
I am completely baffled by this behavior as the server, and all the containers all have the correct time/date.
@Kermit do you have any ideas?
