hi guys, i am using node red but i continuous get stuck on this error:
4 Apr 16:17:44 - TypeError: Cannot read property 'state' of null
at ServerStateChangedNode.onHaEventsStateChanged (/share/node-red/node_modules/node-red-contrib-home-assistant/nodes/server-events-state-changed/server-events-state-changed.js:38:42)
at HaEvents.emit (events.js:185:15)
at HaEvents.onClientMessage (/share/node-red/node_modules/node-home-assistant/lib/ha-events.js:59:22)
at EventSource.client.on (/share/node-red/node_modules/node-home-assistant/lib/ha-events.js:27:49)
at EventSource.emit (events.js:180:13)
at _emit (/share/node-red/node_modules/eventsource/lib/eventsource.js:222:17)
at parseEventStreamLine (/share/node-red/node_modules/eventsource/lib/eventsource.js:237:9)
at IncomingMessage.<anonymous> (/share/node-red/node_modules/eventsource/lib/eventsource.js:200:11)
at IncomingMessage.emit (events.js:180:13)
at addChunk (_stream_readable.js:269:12)
npm info lifecycle [email protected]~start: Failed to exec start script
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: `node $NODE_OPTIONS node_modules/node-red/red.js -v $FLOWS "--userDir" "/share/node-red"`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2018-04-04T14_17_44_612Z-debug.log
i really can’t understand where is my problem. any ideas? thanks
