I’m currently running Node red v14.2.2 - Everything is working fine. I use a lot of home entities (buttons, switches, sensors etc.) (for use on my dashboard)
I tried updating to V14.3 which is now the latest version but I found when my home assistant reboots, all the buttons default to “on” status. So essentially everything breaks on reboot! I set everything up again and then reboot and all the buttons default to on again. Not sure whats going on!! as i can’t see any breaking changes in the update that would cause this.
Steps to reproduce:
Add a home assistant entity (button) using v14.2.2
Add the button to a dashboard
Set the button to off
update to v14.3
Reboot home assistant
The button will now be on,
turn the button off (on the dashboard) and reboot home assistant
The button will be on again after reboot.
It seems like for some reason it isn’t remembering the state anymore after the update.
Yes sorry its the switches that are causing me problems. (I meant buttons in the sense when i create them on the dashboard there essentially buttons i click to enable or disable the switch). So after update
