Any one upgraded to Node Red version 1 yet?
I have it in a docker compose on a NUC not Hassio as:-
image: nodered/node-red-docker:v8
And not sure if this is right in new version:-
Yes and yes.
I upgraded a day or two ago, and so far no issues. To be fair though I don’t have a large amount of automation.
I was previously on nodered/node-red-docker:v10 so I already was on v10 which is what the latest is running. I don’t think going from v8 to v10 would cause you any issues though - but I am no expert.
Cheers!
DeadEnd
Thanks I tried V10 but it lost all my flows so went back to v8.
Luckily I exported all my flows first.
That is very concerning!
Glad you had a backup.
Not sure why that would have happened, but I don’t know much about it.
DeadEnd
Upgraded on day 1 using the nodered/node-red:latest-10 image. I have about 95% of my automations in there and have not had a single issue yet.
And definitely backup first!
I’m upgrading to v1.0 right now - I use git version control for my flows so I can restore them if needed. Thanks for the heads up.
I too have Node Red running under Docker on a NUC (not the add-on). I have upgraded about 10 instances, one of which connects to HA. All suffered the same two minor problems:
Some nodes have been moved to (I assume) separate repositories. For me, suncalc and email disappeared and flows won’t run until you fix the problem. It’s a simple matter of adding them back in via the palette.
Lots of permission problems accessing files. This has something to do with the user that created the folder vs the user NR is now running under. I fixed them by sudo chmod +R 777 /the/folder
, which is probably overkill.
Other than these minor issues, all good. I also took the opportunity to change to running a specific version rather than the default of ‘latest’ (ie. nodered/node-red:1.0.0
). I’m planning on setting up a notification for changes to major/minor version and this seems like an easy way to go (and I hate ‘latest’).
Well I went for it and installed v1 and it failed on this.
4 Oct 13:21:34 - [warn] [node-red-contrib-rfxcom/rfxcom] Error: The module '/data/node_modules/node-red-contrib-rfxcom/node_modules/serialport/build/Release/serialport.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 57. This version of Node.js requires
NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
4 Oct 13:21:34 - [warn] ------------------------------------------------------
Not sure what to do now.
Any Help Please.
The error is for the module node-red-contrib-rfxcom
I would check if there is an updated version of this module that uses an updated node.js version.
Alternatively remove this module, upgrade, and then reinstall it - I expect this could work too.
Either way, the error is telling you that the rfxcom module is the issue.
Cheers!
DeadEnd
Yes thanks i have tried to remove the module and its at its lastest. So i think the module needs to be updated to NODE_MODULE_VERSION 64. So may have to wait for the maintainer of the module to update it.
Edit I Have gone back to Node Red 0.20.8 and all back to normal.
It may be worth asking over at the NodeRED forum, there may already be a fix.
