Node Red v6.12 and Hassio 106.1 Failing
So I just updated to the latest and now all of my node red flows are throwing errors claiming api failure and it keeps doing it nonstop so the processor goes from 2% utilization to 70% and almost all the ram is consumed and the system just crashes. I tried to restore but now all my nodes report errors. Has anyone experienced this and if so how on earth can i fix this without having to start over completely. Thanks
Check the following:
Then double click the Home Assistant Node:
Then check that this checkbox is checked.
This broke for me a couple of days ago with no provocation.
I didn’t uncheck the box, but that was the fix.
Instantly fixed too.
I checked that while it was failing but I think i glossed right over. I’m going to restore the failing build and see if that fixes it. I’ll report back
It took about 20 mins just to access the menu based on the hundreds of errors node red is throwing but this was already checked and configured correctly for me. I’m seeing tons of this and its bogging down the entire system
28 Feb 15:39:59 - [error] [api-call-service:Day State] Call-service API error.
28 Feb 15:39:59 - [error] [api-call-service:In Home State] Call-service API error.
28 Feb 15:39:59 - [error] [api-call-service:Set Day of Week] Call-service API error.
28 Feb 15:40:04 - [info] [server:Home Assistant] WebSocket Connecting http://supervisor/core
28 Feb 15:40:04 - [info] [server:Home Assistant] WebSocket Connected to http://supervisor/core
Uh oh. That sounds bad. I’ve had so many of these lately:
ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host :8123 ssl:False [Connection refused].
I just had to roll back node red to an earlier version. i tried 6.12 a few more times and it did the same thing. There has to be a bug in the build or something.
Bummer.
Stars aligned and burnt you.
