So I will admit, after working on this for a while and trying a few different things, I opted to not use the vacation-timer. I have 14 different lights/switches in the vacation group and each vacation-timer node is good for only one switch. Which means, each vacation-timer node has no knowledge of the other vacation-timer node. I’m not a fan of this, so I did something different.
One of my issues is that the majority of my lights are configured as switches. I also have an irrigation controller, pool, and robot vacuums that use the switch domain, so i had to get a little creative. Anyway, I think I manually created what many of these timers do. Here’s the code if you’re interested:
[{"id":"c0a5e30c.d128c","type":"tab","label":"Vacation Lighting","disabled":false,"info":""},{"id":"e150ca12.186e28","type":"function","z":"c0a5e30c.d128c","name":"Trigger 30% of the time","func":"const random = Math.round(Math.random() * 100);\n\nif(random < 70) {\n node.status({fill: \"red\", text: random});\n return null;\n}\nnode.status({fill: \"green\", text: random});\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":490,"y":360,"wires":[["c189c71b.e2bf78"]]},{"id":"c189c71b.e2bf78","type":"ha-get-entities","z":"c0a5e30c.d128c","server":"84a8d823.e15248","name":"Pick 2 random switches","rules":[{"property":"entity_id","logic":"starts_with","value":"switch.","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.ben_room_switch","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.bush_sprinklers","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.cupboard_light_switch","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.extra_aux","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.front_bushes","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.front_lawn","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.front_porch_light_switch","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.kitchen_table_switch","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.little_hall_switch","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.mr_belvedere_schedule","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.new_program","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.new_program_2","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.north_lawn","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.patio_small_light_switch","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.pool_heater","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.pool_light","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.pool_pump","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.rosie_schedule","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.side_yard","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.solar_heater","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.spa_heater","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.spa_light","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.spa_pump","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.tree_sprinklers","valueType":"str"},{"property":"entity_id","logic":"is_not","value":"switch.waterfall","valueType":"str"}],"output_type":"random","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":"2","x":750,"y":360,"wires":[["43e41bab.227de4"]]},{"id":"154eb6fc.6b3ba9","type":"ha-get-entities","z":"c0a5e30c.d128c","server":"84a8d823.e15248","name":"Pick one random light","rules":[{"property":"entity_id","logic":"starts_with","value":"light.","valueType":"str"}],"output_type":"random","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":740,"y":420,"wires":[["3d2b8ac6.d6eb86"]]},{"id":"14ab8ca4.94b2c3","type":"function","z":"c0a5e30c.d128c","name":"Trigger 25% of the time","func":"const random = Math.round(Math.random() * 100);\n\nif(random < 75) {\n node.status({fill: \"red\", text: random});\n return null;\n}\nnode.status({fill: \"green\", text: random});\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":490,"y":420,"wires":[["154eb6fc.6b3ba9"]]},{"id":"9dd9ef0b.1e282","type":"delay","z":"c0a5e30c.d128c","name":"Switch random for \\n 26 to 51 mins","pauseType":"random","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"26","randomLast":"51","randomUnits":"minutes","drop":false,"x":1230,"y":340,"wires":[["3c0ac01b.0b23f"]]},{"id":"3c0ac01b.0b23f","type":"api-call-service","z":"c0a5e30c.d128c","name":"Turn off switch","server":"84a8d823.e15248","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"{{payload.0.entity_id}},{{payload.1.entity_id}}","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1440,"y":340,"wires":[[]]},{"id":"3d2b8ac6.d6eb86","type":"api-call-service","z":"c0a5e30c.d128c","name":"Turn on Light","server":"84a8d823.e15248","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"{{payload.entity_id}}","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":950,"y":420,"wires":[["c0101aab.97e938"]]},{"id":"c0101aab.97e938","type":"delay","z":"c0a5e30c.d128c","name":"Light random for \\n 29 to 58 mins","pauseType":"random","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"29","randomLast":"58","randomUnits":"minutes","drop":false,"x":1220,"y":440,"wires":[["9ce9a531.d89e28"]]},{"id":"9ce9a531.d89e28","type":"api-call-service","z":"c0a5e30c.d128c","name":"Turn off light","server":"84a8d823.e15248","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"{{payload.entity_id}}","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1430,"y":440,"wires":[[]]},{"id":"43e41bab.227de4","type":"api-call-service","z":"c0a5e30c.d128c","name":"Turn on switch","server":"84a8d823.e15248","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_on","entityId":"{{payload.0.entity_id}},{{payload.1.entity_id}}","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":960,"y":360,"wires":[["9dd9ef0b.1e282"]]},{"id":"6b0a2f7f.d3c6b","type":"poll-state","z":"c0a5e30c.d128c","name":"Check every 10 mins \\n to see if we're home","server":"84a8d823.e15248","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"updateinterval":"10","updateIntervalUnits":"minutes","outputinitially":false,"outputonchanged":false,"entity_id":"group.peeps","state_type":"str","halt_if":"not_home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"x":140,"y":160,"wires":[["ea0f3aa2.e69138"],[]]},{"id":"ea0f3aa2.e69138","type":"time-range-switch","z":"c0a5e30c.d128c","name":"It's between dusk and 2230","lat":"66.44322","lon":"-224.60464","startTime":"dusk","endTime":"22:30","startOffset":0,"endOffset":0,"x":280,"y":260,"wires":[["14ab8ca4.94b2c3","e150ca12.186e28"],[]]},{"id":"84a8d823.e15248","type":"server","z":"","name":"Home Assistant"}]
