Node red ventilation automation
Hi everyone
I have a ventilation device and I would like an automatic one that controls the ventilation based on the amount of co2. If the co2 level is below 800, then operate at 20%, If the co2 level is between 801-1000, then operate at 40% …
v
My ventilation looks like that
Can anyone help me with this?
Don’t you have anything so far?
Nop, I’m not completely in a fog
Could you post the name of the entities involved in this flow please?
And can you post a working Yaml example you use to change the fan mode please ?
Atrea - this is the Ventilation - climate.atrea
CO2- this is a KNX sensor - sensor.co2
i don’t know exactly what are you asking
General idea is as follows. To import this flow copy the code, the whole thing. Then go to your NR instance, click on the three lines in the top right corner and then click import. Paste this code there and click import again.
[{"id":"0952e6fe030cc582","type":"server-state-changed","z":"878e74c2.7f39c8","name":"CO2","server":"9405c3fe.d0a6c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.co2","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":true,"ignorePrevStateUnknown":true,"ignorePrevStateUnavailable":true,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":270,"y":1920,"wires":[["d09aed3a81e7066e"]]},{"id":"d09aed3a81e7066e","type":"switch","z":"878e74c2.7f39c8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"800","vt":"num"},{"t":"btwn","v":"801","vt":"num","v2":"1000","v2t":"num"}],"checkall":"true","repair":false,"outputs":2,"x":410,"y":1920,"wires":[["04d63c32ae620382"],["4cba15f44812163c"]]},{"id":"04d63c32ae620382","type":"api-call-service","z":"878e74c2.7f39c8","name":"fan_mode 20%","server":"9405c3fe.d0a6c","version":5,"debugenabled":false,"domain":"","service":"","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":620,"y":1880,"wires":[[]]},{"id":"4cba15f44812163c","type":"api-call-service","z":"878e74c2.7f39c8","name":"fan_mode 40%","server":"9405c3fe.d0a6c","version":5,"debugenabled":false,"domain":"","service":"","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":620,"y":1920,"wires":[[]]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
I assume you’ve only manipulated your entity through the UI, never used code, and without the code I don’t know how to set the fan_mode in NR.
What device is that entity? what integration did you use to integrate this device?
Thank you for you help. I managed to solve the problem. Everything works fine
