Hi all,
I have and an Hassio and Node-Red installation on a Rpi2. I have been following this Node-Red watchdog video (https://www.youtube.com/watch?v=0iGq3izVklY). I have set up the automation as explained in the video but my automation does not trigger!
I have set up the automation using the Hassio Automation Editor and the resulting automation in my automation.yaml file is as follows (this was auto-generated by the Automation Editor) :
- id: '1542219219882'
alias: Reset NodeRED Watchdog
- entity_id: sensor.node_red
platform: state
to: unkown
condition: []
- data:
addon: a0d7b954_nodered
service: hassio.addon_restart
The idea with this automation is that the Node-Red addon should be restarted when the “sensor.node_red” changes from OK to unknown. I can see in my hassio logbook that the sensor changes to Unknown, but the automation does not execute.
In the Hassio Automation Editor in the Actions section, I hade to add json text for the service data. If I use this same json text in the services function (leftmost icon at the bottom of HA page) I can restart the Node-Red addon. This means that the json values are correct.
Does anybody know how I can check why the automation does not trigger?
