I disabled some flows yesterday no problem…
This am, I could not get back in.
The log does not have any errors in it…
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 18.0.3
You are running the latest version of this add-on.
System: Home Assistant OS 12.4 (amd64 / qemux86-64)
Home Assistant Core: 2024.7.1
Home Assistant Supervisor: 2024.06.2
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
[10:18:31] INFO: Starting installation of custom NPM/Node-RED packages…
s6-rc: info: service init-nginx successfully started
npm warn config optional Use --omit=optional
to exclude optional dependencies, or
npm warn config --include=optional
to include them.
npm warn config
npm warn config Default value does install optional deps unless otherwise omitted.
npm warn config only Use --omit=dev
to omit dev dependencies from the install.
added 3 packages, and audited 828 packages in 7s
