Running the folowing;
- Core2024.12.5
- Supervisor2024.12.0
- Operating System14.1
- Frontend20241127.8
Loaded Node Red version 18.1.1, however it wont run.
Log file;
s6-rc: info: service nodered: stopping
[18:20:43] INFO: e[32mService Node-RED exited with code 256 (by signal 15)e[0m
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
e[34m-----------------------------------------------------------e[0m
e[34m Add-on: Node-REDe[0m
e[34m Flow-based programming for the Internet of Thingse[0m
e[34m Add-on version: 18.1.1e[0m
e[32m You are running the latest version of this add-on.e[0m
e[34m System: Home Assistant OS 14.1 (aarch64 / raspberrypi4-64)e[0m
e[34m Home Assistant Core: 2024.12.5e[0m
e[34m Home Assistant Supervisor: 2024.12.0e[0m
e[34m Please, share the above information when looking for helpe[0m
e[34m or support in, e.g., GitHub, forums or the Discord chat.e[0m
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
[18:20:49] FATAL: e[31me[0m
[18:20:49] FATAL: e[31mSSL has been enabled using the ‘ssl’ option,e[0m
[18:20:49] FATAL: e[31mthis requires an SSL certificate file which ise[0m
[18:20:49] FATAL: e[31mconfigured using the ‘certfile’ option in thee[0m
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
[18:20:49] FATAL: e[31madd-on configuration.e[0m
s6-rc: info: service nodered successfully started
[18:20:49] FATAL: e[31mUnfortunately, the file specified in thee[0m
[18:20:49] FATAL: e[31m’certfile’ option does not exist.e[0m
[18:20:49] FATAL: e[31mPlease ensure the certificate file exists ande[0m
[18:20:49] FATAL: e[31mis placed in the ‘/ssl/’ directory.e[0m
[18:20:49] FATAL: e[31mIn case you don’t have SSL yet, consider gettinge[0m
[18:20:49] FATAL: e[31man SSL certificate or setting the ‘ssl’ optione[0m
[18:20:49] FATAL: e[31mto ‘false’ in case you are not planning on usinge[0m
[18:20:49] FATAL: e[31mSSL with this add-on.e[0m
[18:20:49] FATAL: e[31mCheck the add-on manual for more information.e[0m
s6-rc: warning: unable to start service init-nginx: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
[18:20:49] INFO: e[32mService Node-RED exited with code 256 (by signal 15)e[0m
[18:20:55] FATAL: e[31me[0m
[18:20:55] FATAL: e[31mSSL has been enabled using the ‘ssl’ option,e[0m
[18:20:55] FATAL: e[31mthis requires an SSL certificate file which ise[0m
[18:20:55] FATAL: e[31mconfigured using the ‘certfile’ option in thee[0m
[18:20:55] FATAL: e[31madd-on configuration.e[0m
[18:20:55] FATAL: e[31mUnfortunately, the file specified in thee[0m
[18:20:55] FATAL: e[31m’certfile’ option does not exist.e[0m
[18:20:55] FATAL: e[31mPlease ensure the certificate file exists ande[0m
[18:20:55] FATAL: e[31mis placed in the ‘/ssl/’ directory.e[0m
[18:20:55] FATAL: e[31mIn case you don’t have SSL yet, consider gettinge[0m
[18:20:55] FATAL: e[31man SSL certificate or setting the ‘ssl’ optione[0m
[18:20:55] FATAL: e[31mto ‘false’ in case you are not planning on usinge[0m
[18:20:55] FATAL: e[31mSSL with this add-on.e[0m
[18:20:55] FATAL: e[31mCheck the add-on manual for more information.e[0m
[18:20:55] INFO: e[32mService Node-RED exited with code 256 (by signal 15)e[0m
[18:21:01] FATAL: e[31me[0m
[18:21:01] FATAL: e[31mSSL has been enabled using the ‘ssl’ option,e[0m
[18:21:01] FATAL: e[31mthis requires an SSL certificate file which ise[0m
[18:21:01] FATAL: e[31mconfigured using the ‘certfile’ option in thee[0m
[18:21:01] FATAL: e[31madd-on configuration.e[0m
[18:21:01] FATAL: e[31mUnfortunately, the file specified in thee[0m
[18:21:01] FATAL: e[31m’certfile’ option does not exist.e[0m
[18:21:01] FATAL: e[31mPlease ensure the certificate file exists ande[0m
[18:21:01] FATAL: e[31mis placed in the ‘/ssl/’ directory.e[0m
[18:21:01] FATAL: e[31mIn case you don’t have SSL yet, consider gettinge[0m
[18:21:01] FATAL: e[31man SSL certificate or setting the ‘ssl’ optione[0m
[18:21:01] FATAL: e[31mto ‘false’ in case you are not planning on usinge[0m
[18:21:01] FATAL: e[31mSSL with this add-on.e[0m
[18:21:01] FATAL: e[31mCheck the add-on manual for more information.e[0m
[18:21:01] INFO: e[32mService Node-RED exited with code 256 (by signal 15)e[0m
Turn off ssl on the config page.
