When trying to start node-red on new hardware platform after doing restore snapshot from old instance (Same versions of core, supervisor, and host) I’m getting these messages:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 6.1.4
There is an update available for this add-on!
Latest add-on version: null
Please consider upgrading as soon as possible.
System: HassOS 3.12 (amd64 / qemux86-64)
Home Assistant Core: 0.107.7
Home Assistant Supervisor: 214
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing...
[12:42:29] INFO: Password is NOT in the Have I Been Pwned database! Nice!
[12:42:32] INFO: Password is NOT in the Have I Been Pwned database! Nice!
patching file nodes/ui_base.html
Hunk #1 succeeded at 1243 (offset 712 lines).
buffer.js:585
slice: (buf, start, end) => buf.utf8Slice(start, end),
RangeError: Index out of range
at Object.slice (buffer.js:585:37)
at Buffer.toString (buffer.js:782:14)
at Object.readFileSync (fs.js:386:41)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:990:22)
at Module.load (internal/modules/cjs/loader.js:811:32)
at Function.Module._load (internal/modules/cjs/loader.js:723:14)
at Function.Module.runMain (internal/modules/cjs/loader.js:1043:10)
at internal/main/run_main_module.js:17:11 {
code: 'ERR_OUT_OF_RANGE'
[12:42:35] FATAL: Failed un-installing conflicting packages
[cont-init.d] node-red.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
Be sure to check the log above, line by line, for hints.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Appreciate any and all help
