Hi
I’m still getting to grips with YAML and JSON formatting so please bear with me. I have several automations written in YAML but I am experimenting with Nodered with the aim of moving over.
I currently have an node red automation that successfully turns a light on/off when I want. But when I try and incorporate the light effect, which works in YAML I get an API error in nodered.
The YAML config is:
entity_id: light.bedside_lights
effect: Wake up
which when I format as JSON, I believe should be
"entity_id": "light.bedside_lights",
"data": {
"effect": "Wake up"
when I paste this into the data field of the call service node in nodered as below
I get an API error when the automation runs. Pretty sure it is my ignorance in formatting JSON
