EDIT: Solved. As so often the case, this was typical ID10T error. I was under the impression that restarting Homeassistant from the Settings menu was performing a reboot on the Raspberry Pi that everything is running on. That is however not correct, so through all my restarts, uninstalls and re-installs, I never actually rebooted the host machine. A simple reboot command through the Terminal add-on caused all the described problems to disappear.
Not a complete loss though, as I did learn a lot in the process of tracking down this non-existant problem.
So after running into problems with node-red as described here: Accidentally broke a working Node-Red/HA setup. Maybe by deleting "server"?, I decided to roll back to a backup from last week and re-install.
Running Hass OS on a Raspberry Pi, latest versions for everything.
I enter the necessary bits in the config tab for the node-red addon, turning ssl off, and hit start.
After a while, the log looks ok (see below), but when I try the node-red companion, it tells me that node-red ins’r running and that I need to start it. In the info tab of the add-on UI, I still only see the “start” and “uninstall” buttons, not the usual “Restart” and “open UI” buttons. Hitting the start button again does nothing. No change in status and nothing added to the log either.
I have rebooted HA multiple times as well as uninstalled and re-installed the add-on, to no avail.
Any ideas what might be wrong here?
Here’s the log, as taken from the add-on UI. The repeated connection attempts to supervisor do look a bit suspicious, but there’s no error in there, or anything that tells me what’s wrong:
Edit: not sure if this is relevant, but the Settings file mentioned in the log, at /etc/node-red/config.js doesn’t seem to exist. In fact there is no /etc/node-red directory at all.
28 Sep 20:57:21 - [info]
Welcome to Node-RED
28 Sep 20:57:21 - [info] Node-RED version: v3.0.2
28 Sep 20:57:21 - [info] Node.js version: v16.16.0
28 Sep 20:57:21 - [info] Linux 5.15.61-v8 arm64 LE
28 Sep 20:57:25 - [info] Loading palette nodes
28 Sep 20:57:37 - [info] Dashboard version 3.2.0 started at /endpoint/ui
28 Sep 20:57:41 - [info] Settings file : /etc/node-red/config.js
28 Sep 20:57:41 - [info] Context store : 'default' [module=memory]
28 Sep 20:57:41 - [info] User directory : /config/node-red/
28 Sep 20:57:41 - [warn] Projects disabled : editorTheme.projects.enabled=false
28 Sep 20:57:41 - [info] Flows file : /config/node-red/flows.json
28 Sep 20:57:41 - [warn] Encrypted credentials not found
28 Sep 20:57:41 - [info] Server now running at http://127.0.0.1:46836/
28 Sep 20:57:41 - [info] Starting flows
28 Sep 20:57:41 - [info] Started flows
[20:57:41] INFO: Starting NGinx...
28 Sep 20:57:46 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 20:57:47 - [info] [server:Home Assistant] Connected to http://supervisor/core
28 Sep 21:00:08 - [info] [server:Home Assistant] Connection closed to http://supervisor/core
28 Sep 21:00:13 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:00:18 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:00:23 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:00:28 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:00:33 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:00:38 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:00:43 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:00:48 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:00:53 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:00:58 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:01:05 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:01:11 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:01:16 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:01:22 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:01:29 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:01:35 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:01:40 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:01:45 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:01:47 - [info] [server:Home Assistant] Connected to http://supervisor/core
28 Sep 21:11:09 - [info] [server:Home Assistant] Connection closed to http://supervisor/core
28 Sep 21:11:14 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:11:19 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:11:24 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:11:29 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:11:34 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:11:39 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:11:44 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:11:49 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:11:55 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:12:00 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:12:05 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:12:10 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:12:15 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:12:22 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:12:30 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:12:35 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:12:40 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:12:44 - [info] [server:Home Assistant] Connected to http://supervisor/core
28 Sep 21:17:06 - [info] [server:Home Assistant] Connection closed to http://supervisor/core
28 Sep 21:17:11 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:17:16 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:17:21 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:17:26 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:17:31 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:17:36 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:17:42 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:17:47 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:17:52 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:17:57 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:18:02 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:18:07 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:18:12 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:18:18 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:18:24 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:18:29 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:18:35 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Sep 21:18:38 - [info] [server:Home Assistant] Connected to http://supervisor/core
29 Sep 06:36:38 - [info] [server:Home Assistant] Connection closed to http://supervisor/core
29 Sep 06:36:43 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:36:48 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:36:53 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:36:58 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:37:03 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:37:08 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:37:13 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:37:18 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:37:23 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:37:28 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:37:34 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:37:39 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:37:44 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:37:51 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:37:59 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:38:08 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:38:13 - [info] [server:Home Assistant] Connecting to http://supervisor/core
29 Sep 06:38:14 - [info] [server:Home Assistant] Connected to http://supervisor/core
