NodeJS on Hass.io
Hi All,
I currently run a Hassbian build and would like to migrate to Hass.io.
I have a few scripts that I currently run using NodeJS to control my garage door and alarm system. Is there a way to run these Node scripts in Hass.io?
Any help would be appreciated.
Cheers,
Kaz
I managed to create a local addon with NodeJS.
Can you share what you did? I’m very interested in being able to integrate NodeJS code with Hass.io.
I basically created a HASS addon that installs NodeJS in a docker container.
Inside the container, I’m running an Express API that I connect from HASS to retrieve some sensor data.
This is what my Dockerfile looks like:
FROM %%BASE_IMAGE%%
ENV LANG C.UTF-8
RUN apk add --no-cache nodejs-current yarn && \
yarn global add npm && \
yarn cache clean && \
apk del yarn && \
npm set unsafe-perm true && \
npm install install express request
# Expose tcp/8081
EXPOSE 8088
# Copy data for add-on
# Bundle app source
COPY . /
COPY run.sh /
RUN chmod a+x /run.sh
CMD [ "/run.sh" ]
How’s your config and run.sh looks like?
//Gustafsson
Are you please able to elaborate on this for the newer peeps like myself? I’ve just moved to hass.io and discovered I need node back for my kodi voice control. :slight_smile:
Here is a working addon i wrote in NodeJS for home assistant
you can take the dockerfile from there
Have a look at https://github.com/helmut-hoffer-von-ankershoffen/hassio-ring-bridge for a Home Assistant -> Ring bridge built as an addon in NodeJS.
Hey guys, any update on this?
I’m using exact the same Dockerfile and run.sh as you, but I always get the error:
The command '/bin/bash -o pipefail -c cd / && npm install --unsafe-perm' returned a non-zero code: 1
Is your code outdated or did I miss something?
Here’s another NodeJS addon starter project. Works for me. hassio-addons/hassio-addon-nodejs-starter at master · kdw2060/hassio-addons · GitHub
HACS says now: “Repostitory structure for master is not compliant”
What is it that you are trying to install? The ring integration or nodered? If you are not running a supervised install and only the core in docker use the regular docker setup for nodered. Then add HA web socket to integrate in home assistant.
https://nodered.org/docs/getting-started/
HACS is not for add-ons, it makes you click ‘i have read and understand that HACS does not contain add-ons’ when you install it. Still they’re so friendly to provide a link to the supervisor-area where you can install add-ons. So head over to supervisor > add-on store and try again.
You again? With your confused idea of NODE RED?
