NodeMcu LUA D1 mini WIFI ESP-12F module with ESP8266 and bme280
Hello trying to connect NodeMcu LUA D1 to BMP280 5V something just don’t work, I can’t have the sensors data, maybe someone has good instructions
this is my code:
# Example configuration entry for ESP32
i2c:
#  sda: 21
#  scl: 22
  scan: true
  - platform: bmp280
    temperature:
      name: "Outside Temperature"
      oversampling: 16x
    pressure:
      name: "Outside Pressure"
    i2c_id: bus_a
    address: 0x76
    update_interval: 10s
this is part of the message I get Wen I flash it:
[23:12:37][C][i2c.arduino:032]: I2C Bus:
[23:12:37][C][i2c.arduino:033]: SDA Pin: GPIO4
[23:12:37][C][i2c.arduino:034]: SCL Pin: GPIO5
[23:12:37][C][i2c.arduino:035]: Frequency: 50000 Hz
[23:12:37][C][i2c.arduino:038]: Recovery: bus successfully recovered
[23:12:37][I][i2c.arduino:048]: Scanning i2c bus for active devices…
[23:12:37][I][i2c.arduino:060]: Found no i2c devices!
[23:12:38][C][bmp280.sensor:098]: BMP280:
[23:12:38][C][bmp280.sensor:099]: Address: 0x76
[23:12:38][E][bmp280.sensor:102]: Communication with BMP280 failed!
Your whole yaml please.
Whole yaml and wiring schema (as always for help…) !
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "c470ddc36067236a76ff7898b06ac24a"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Temperaturetry Fallback Hotspot"
    password: "********
captive_portal:
i2c:
#  sda: 21
#  scl: 22
  scan: true
  - platform: bmp280
    temperature:
      oversampling: 16x
    pressure:
    i2c_id: bus_a
    address: 0x76
Obvious question, but are SCK / SDI actually connected to GPIO4 / GPIO5 (D1 / D2) (the i2c defaults) ?
Oh, and not sure what the 5V in OP means here. You have to connect it to 3.3.V (the schema on Ali show you that)
not so obvious to me…
Is there any schema I can watch how to connect every pin correctly ?
this is the module module and this module
