Hello guys,
I am stuck with my Si7021 i2c sensor on my NodeMCU V3 (“LoLin new NodeMcu V3”) as the i2c connection appears to work but there are no sensor values coming.
3.3V – Connected to 3v on nodemcu
GND – Connected to GND pin on nodemcu
SDA – Connected to D2 on nodemcu
SCL – Connected to D1 on nodemcu
esphome:
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "***"
ota:
password: "***"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Test-Si7021 Fallback Hotspot"
password: "***"
captive_portal:
i2c:
sda: D2
scl: D1
scan: True
- platform: htu21d
i2c_id: htu_21d
temperature:
humidity:
update_interval: 60s
This is what I keep getting. I replaced the Si7021 as well as the NodeMCU and the error remains the same. What is strange to me is that the i2c scan finds the device so that I am not sure whether the sensor is the issue or it is rather the nodemcu. The cable length is about 15cm (standard jumper wires).
[20:39:25][C][logger:277]: Log Baud Rate: 115200
[20:39:25][C][logger:278]: Hardware UART: UART0
[20:39:25][C][i2c.arduino:038]: I2C Bus:
[20:39:25][C][i2c.arduino:039]: SDA Pin: GPIO4
[20:39:25][C][i2c.arduino:040]: SCL Pin: GPIO5
[20:39:25][C][i2c.arduino:041]: Frequency: 50000 Hz
[20:39:25][C][i2c.arduino:044]: Recovery: bus successfully recovered
[20:39:25][I][i2c.arduino:054]: Results from i2c bus scan:
[20:39:25][I][i2c.arduino:060]: Found i2c device at address 0x40
[20:39:25][C][htu21d:028]: HTU21D:
[20:39:25][C][htu21d:029]: Address: 0x40
[20:39:25][C][htu21d:033]: Update Interval: 60.0s
[20:39:25][C][htu21d:034]: Temperature 'sensor.temperatur'
[20:39:25][C][htu21d:034]: Device Class: 'temperature'
[20:39:25][C][htu21d:034]: State Class: 'measurement'
[20:39:25][C][htu21d:034]: Unit of Measurement: '°C'
[20:39:25][C][htu21d:034]: Accuracy Decimals: 1
[20:39:25][C][htu21d:035]: Humidity 'sensor.feuchtigkeit'
[20:39:25][C][htu21d:035]: Device Class: 'humidity'
[20:39:25][C][htu21d:035]: State Class: 'measurement'
[20:39:25][C][htu21d:035]: Unit of Measurement: '%'
[20:39:25][C][htu21d:035]: Accuracy Decimals: 1
[20:39:26][C][captive_portal:088]: Captive Portal:
[20:39:26][C][mdns:094]: mDNS:
[20:39:26][C][mdns:095]: Hostname: sensor-multi-buero
[20:39:26][C][ota:089]: Over-The-Air Updates:
[20:39:26][C][ota:090]: Address: 10.10.50.91:8266
[20:39:26][C][ota:093]: Using Password.
[20:39:26][C][api:138]: API Server:
[20:39:26][C][api:139]: Address: 10.10.50.91:6053
[20:39:26][C][api:141]: Using noise encryption: YES
[20:39:39][D][api:102]: Accepted 10.10.10.30
[20:39:39][D][api.connection:861]: Home Assistant 2022.9.6 (10.10.10.30): Connected successfully
Any ideas?
It’s not „NaN“ or Null, there is literally nothing being sent…
