Home Assistant: 2020.12.7
ESPHome: v.1.15.3
Sensor: NodeMCU (with MQTT)
I have several NodeMCU sensors flashed with ESPHome using simple output-/switch configuration.
Over night my home assistant and MQTT servers are not available.
During that time my ESPHome based sensors do reboot every 5 minutes.
If I understand the documentation correctly then this should only happen if you use the keyword: “api” in *.yml configuration and I don’t use this. (see example configuration below)
Any ideas why my sensors reboots every 5 minutes?
Base configuration:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_ssid
# Enable logging
logger:
level: INFO
ota:
password: !secret ota_password
mqtt:
broker: !secret mqtt_broker_ip
username: !secret mqtt_username
password: !secret mqtt_password
output and switches
