Hi, I am using nodemcu (esp8266) with esphome and two sensors connected via I2C: One of them is bme680 and the second is scd41. The sensor values are also shown correctly in the Home Assistant Dashboard. Home Assistent and all plugins are updated to the latest SW version. The issue is: if i want to trigger an automation using these sensor values (only showing a notification with the HA app), nothing happens. The notification appears on my mobile phone only if I trigger the automation manually. The issue seems to be limited to the sensors connected via the NodeMCU because other sensors trigger an automation / notification without any issue. Here is my configuration, for example, for raising a notification on the app if the temperature is above 20° Celcuis. The automation is generated with the wizard:
alias: myNewBME680automation
description: ""
- type: temperature
platform: device
device_id: 90cd04e6989451724c6d66a80d8a95dc
entity_id: 732550aa0b71b593c44d8966f367934d
domain: sensor
above: 20
condition: []
- device_id: 440c49d85f802b8baa5fec230f0941c7
domain: mobile_app
type: notify
message: myBME680 notification
title: myBME680title
mode: single
