hi i have running 2 sensors in ESPHOME, one for my smart power meter and anotherone for my gas consumption. Both sensors use a NodeMCU V3 ESP8266. Is it possible to put both sensors together and use only one NodeMCU? Here is my config for the smartmeter
uart:
rx_pin: GPIO3
baud_rate: 9600
data_bits: 7
parity: ODD
debug:
and the following one is from my gas consumption:
binary_sensor:
- platform: gpio
pin:
number: GPIO5
mode: INPUT_PULLUP
filters:- delayed_on: 10ms
on_press:
then:- lambda: id(total_pulses) += 1;
- delayed_on: 10ms
Both sensors are conneccted to VIN and GND. Do i have to solder the cables together or can one sensors use VIN and GND on the left side and the other one uses the 3.3V and GND pins on the other side?
