NodeRED Addon stops with "Failed un-installing conflicting packages" message
I upgraded some nodes via the palette manger and then restarted NodeRED but it’s now failing after a few seconds. “Failed un-installing conflicting packages”. Maybe an NPM related problem ? I am trying to find the logfile it references - where would it be exactly - which container ? I can’t open a session to the NodeRED container because it just stops after starting
I tried restoring a backup of NodeRED from 3 days ago (known working) but no change and I tried restoring a complete backup from 3 days ago - still the same error. So this seems to be in a residual area after the backup is restored - maybe the main OS ? {edit} I now know the issue is in config/node-red directory.
Any help much appreciated
Ancillary question… If I uninstall and then re-install the NodeRED addin will I lose all my flows and installed nodes? I have a backup of lows but I had a lot of nodes installed…
Running H A Supervised, latest versions
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] customizations.sh: executing...
[cont-init.d] customizations.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing...
patching file nodes/ui_base.html
Hunk #1 succeeded at 1162 (offset 631 lines).
npm ERR! Cannot convert undefined or null to object
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2021-12-02T02_37_24_412Z-debug.log
[02:37:24] FATAL: Failed un-installing conflicting packages
[cont-init.d] node-red.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
I have the same problem…is there any solution to this?
I had the same think show up yesterday. Now Node-Red wont start, even when I restore a 2 week-old backup!. Was working fine, even after restarts before. I did no updates or anything that I know of.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: Node-RED
 Flow-based programming for the Internet of Things
 Add-on version: 11.1.2
 You are running the latest version of this add-on.
 System: Debian GNU/Linux 11 (bullseye)  (amd64 / qemux86-64)
 Home Assistant Core: 2022.5.5
 Home Assistant Supervisor: 2022.05.3
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
Hunk #1 succeeded at 1164 (offset 633 lines).
npm ERR!     /root/.npm/_logs/2022-05-27T12_12_03_693Z-debug.log
[07:12:03] FATAL: Failed un-installing conflicting packages
[s6-finish] sending all processes the KILL signal and exiting.
Try enabling safe mode then removing the problem node. See the documentation page of the addon for how to enable safe mode.
I am too having the same issue. I tried starting in safe mode but it still comes up with same error.
[fix-attrs.d] done.
 Add-on: Node-RED
 System: Home Assistant OS 8.1  (aarch64 / odroid-n2)
npm ERR!     /root/.npm/_logs/2022-05-28T01_41_41_411Z-debug.log
[18:41:41] FATAL: Failed un-installing conflicting packages
I finally got it working. I tried logging in, in safe mode that didn’t work. I tried removing and reinstalling node red that didn’t work. I reverted back to an older back up version of HA, that didn’t work. Finally, I was able to get it working but I am not sure if this is the correct way to fix it. Here is what I ended up doing. I stopped the program from running. I backed up my flows file so I would not lose my automations. (flows.json) I then uninstalled the program in home assistant. This does not remove all files. I then accessed the node-red folder and deleted the package.json and package-lock.json files by backing them up to another folder just in case. I then restarted home assistant and reinstalled node-red. After this everything appears to be working normal. I hope this is helpful.
That is how I got mine working again too after trying lots of other paths.
