Event: state node, with a tiny bit of JSONata and the time-date integration using sensor.time
$entity().state="05:00" and $entities('sun.sun').state="below_horizon"
As long as you have sensor.time to provide local time as “hh:mm”, the node state condition will only be true when time is 5AM and it is before sunrise.
[{"id":"5b8cf2ba61949b6e","type":"server-state-changed","z":"e6f8ea0317d4f26a","name":"5AM before sunrise","server":"","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.time","entityIdType":"exact","outputInitially":false,"stateType":"str","ifState":"$entity().state=\"05:00\" and $entities('sun.sun').state=\"below_horizon\"","ifStateType":"jsonata","ifStateOperator":"jsonata","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":430,"y":1880,"wires":[["8238d0e4229e9849"],["a0c9515da9b5af71"]]}]
No - the sun.sun and sensor.sun_* does, but you need to add ‘time’ integration by hand.
I have added mine using the YAML configuration settings, which still work, but I note that there is now a ‘time-date’ integration, and you have to add this and create an entity for each ‘time/date’ you want. I find the ‘time’ very useful, as it updates every minute and being local deals with timezone and DST. The UTC and ISO times are also very useful (as most parsing only likes ISO formatted timestamps).
If it is any help, I have the following in my config YAML and this works a treat, but if you are starting from scratch, use the time-date integration.
