NodeRed Domain,Service, Device, Entity all not working
I am losing my mind. I have followed every tutorial, read all the documentation, watched dozens of videos, and yet, something is clearly wrong with my setup. I can not for the life of me deploy a flow, sequence, or get field the populate.
Even the simplest flow after deployed shows no “running” icon nor are there any logs to check. What is worse, is when I use the “call service” node, Domain, Service simply show “No results found” the list of my entities are also incomplete as well as my devices. Is something wrong with my install? I have completely uninstalled and re-installed multiple times in addition to restarting and rebooting my device. Any and all help appreciated.
Did you install Node Red as an add-on? Post your problem flow.
Yes installed it as an addon. It is any flow I attempt, it will not work. I tried even using a debug node after the state change node, and after deploying, it does not run nor will it output any issues
I deleted the server connection and then re-added with “Use home assistant addon”, this has fixed my issue now. thank you!
Try something simple just to make sure Node Red is working.
NR
