Inspired by @valvex and it’s great work here https://community.home-assistant.io/t/monitoring-your-unifi-ap/259703?u=sdomotica_automation and with some issue with Python Script, I decided to implement mine using Nodered and Mqtt dicover features of Home Assistant.
You can see all the infos of your AP and you can block and unblock all the devices connetecred
You can also turn-on / turn-off the AP led
Each component has attributes with info as IP address, statistics etc.
Here the Nodered Flow
I use this palette, that you have to install before import my flow
https://flows.nodered.org/node/node-red-contrib-unifi
[{"id":"3366c513d01846b6","type":"Unifi","z":"ca15b45a6a5a96ab","name":"","server":"0bbadfcf8bb33bc7","command":"30","debug":false,"x":330,"y":100,"wires":[["b7179904bebb3a88","05af66cd7cce372f","b2139d9142b197ad"]]},{"id":"9763d22b7dba8ff7","type":"inject","z":"ca15b45a6a5a96ab","name":"AllUsers","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"240","crontab":"","once":true,"onceDelay":"10","topic":"AllUsers","payload":"{\"command\": \"AllUsers\"}","payloadType":"json","x":100,"y":140,"wires":[["3366c513d01846b6"]]},{"id":"b7179904bebb3a88","type":"switch","z":"ca15b45a6a5a96ab","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"AllUsers","vt":"str"},{"t":"eq","v":"ClientDevices","vt":"str"},{"t":"eq","v":"Blocking","vt":"str"},{"t":"eq","v":"AccessDevices","vt":"str"},{"t":"eq","v":"Led","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":6,"x":530,"y":140,"wires":[["37ca55753a131511"],["b963e534079fc751"],["6386d006de2ba9fc"],["6e99d5d9567aa493"],["e081d7ad10a31626"],[]]},{"id":"37ca55753a131511","type":"function","z":"ca15b45a6a5a96ab","name":"AllUsers","func":"const a = msg.payload\nvar unifi_id = []\nvar unifi_id_blocked = []\n\na.forEach((element) => {\n unifi_id.push(element._id)\n if (typeof element.hostname != \"undefined\"){\n var nome = \"Unifi: \" + element.hostname\n } else {\n if (element.oui != \"\") {\n nome = \"Unifi: \" + element.oui\n } else {\n nome = \"Unifi: \" + element.mac\n }\n }\n\n\n msg.topic = \"homeassistant/switch/\" +element._id + \"/config\"\n msg.payload = {\n \"name\": nome,\n \"unique_id\": \"unifiswitch\" + element._id,\n \"icon\": \"mdi:lan\",\n \"availability_topic\": \"homeassistant/unifi/\" + element._id + \"/availability\",\n \"json_attributes_topic\": \"homeassistant/unifi/\" + element._id + \"/json\",\n \"state_topic\": \"homeassistant/unifi/\" + element._id + \"/state\",\n \"command_topic\": \"homeassistant/unificmd/\" + element._id + \"/\" + element.mac\n\n }\n\n //msg.payload = element\n node.send(msg);\n\n});\nflow.set(\"unifiusers\", a)\nmsg.topic = \"endsetup\"\nmsg.payload = \"end\"\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":80,"wires":[["3e991dc8c13a492a"]]},{"id":"3e991dc8c13a492a","type":"switch","z":"ca15b45a6a5a96ab","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"endsetup","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":930,"y":80,"wires":[["23769bdba7c78250"],["fcb8c4111f3bddd0"]]},{"id":"fcb8c4111f3bddd0","type":"mqtt out","z":"ca15b45a6a5a96ab","name":"","topic":"","qos":"","retain":"true","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"dac17249.b02d3","x":1310,"y":240,"wires":[]},{"id":"23769bdba7c78250","type":"change","z":"ca15b45a6a5a96ab","name":"Ask Clients","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"command\":\"ClientDevices\"}","tot":"json"},{"t":"set","p":"topic","pt":"msg","to":"ClientDevices","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":80,"wires":[["ea9d4502fb30ca23"]]},{"id":"b963e534079fc751","type":"function","z":"ca15b45a6a5a96ab","name":"All clients status","func":"const a = msg.payload\nconst unifiusers = flow.get(\"unifiusers\")\nvar unificlient = []\n\n\na.forEach((element) => {\n var attributi = {}\n unificlient.push(element._id)\n //send online status\n msg.topic = \"homeassistant/unifi/\" + element._id + \"/availability\"\n msg.payload = \"online\"\n node.send(msg); \n\n //send client status\n if (typeof element.blocked != \"undefined\"){\n if (element.blocked == true) {\n var stato = \"OFF\"\n } else {\n stato = \"ON\"\n }\n } else {\n stato = \"ON\"\n }\n\n msg.topic = \"homeassistant/unifi/\" + element._id + \"/state\"\n msg.payload = stato\n node.send(msg);\n\n //send client attributes\n if (typeof element.mac != \"undefined\") { attributi[\"mac\"] = element.mac }\n if (typeof element.last_seen != \"undefined\") { attributi[\"last_seen\"] = element.last_seen }\n if (typeof element._uptime_by_uap != \"undefined\") { attributi[\"_uptime_by_uap\"] = element._uptime_by_uap }\n if (typeof element.channel != \"undefined\") { attributi[\"channel\"] = element.channel }\n if (typeof element.radio != \"undefined\") { attributi[\"radio\"] = element.radio }\n if (typeof element.radio_name != \"undefined\") { attributi[\"radio_name\"] = element.radio_name }\n if (typeof element.essid != \"undefined\") { attributi[\"essid\"] = element.essid }\n if (typeof element.ip != \"undefined\") { attributi[\"ip\"] = element.ip }\n if (typeof element.noise != \"undefined\") { attributi[\"noise\"] = element.noise }\n if (typeof element.nss != \"undefined\") { attributi[\"nss\"] = element.nss }\n if (typeof element.rx_rate != \"undefined\") { attributi[\"rx_rate\"] = element.rx_rate }\n if (typeof element.rssi != \"undefined\") { attributi[\"rssi\"] = element.rssi }\n if (typeof element.satisfaction != \"undefined\") { attributi[\"satisfaction\"] = element.satisfaction }\n if (typeof element.satisfaction_now != \"undefined\") { attributi[\"satisfaction_now\"] = element.satisfaction_now }\n if (typeof element.signal != \"undefined\") { attributi[\"signal\"] = element.signal }\n if (typeof element.uptime != \"undefined\") { attributi[\"uptime\"] = element.uptime }\n if (typeof element.tx_bytes != \"undefined\") { attributi[\"tx_bytes\"] = element.tx_bytes }\n if (typeof element.rx_bytes != \"undefined\") { attributi[\"rx_bytes\"] = element.rx_bytes }\n if (typeof element.tx_packets != \"undefined\") { attributi[\"tx_packets\"] = element.tx_packets }\n if (typeof element.rx_packets != \"undefined\") { attributi[\"rx_packets\"] = element.rx_packets }\n if (typeof element.blocked != \"undefined\") { attributi[\"blocked\"] = element.blocked }\n\n msg.topic = \"homeassistant/unifi/\" + element._id + \"/json\"\n msg.payload = attributi\n node.send(msg);\n\n});\n\n//put offline other Users\nunifiusers.forEach((element) => {\n if (unificlient.indexOf(element._id) !== -1) {\n //client already managed as connected\n } else {\n //check if client has beed disabled\n if (typeof element.blocked != \"undefined\" && element.blocked == true) { \n msg.topic = \"homeassistant/unifi/\" + element._id + \"/availability\"\n msg.payload = \"online\"\n node.send(msg);\n msg.topic = \"homeassistant/unifi/\" + element._id + \"/state\"\n msg.payload = \"OFF\"\n node.send(msg); \n } else {\n //not disable thus unvaiable\n msg.topic = \"homeassistant/unifi/\" + element._id + \"/availability\"\n msg.payload = \"offline\"\n node.send(msg); \n }\n }\n})\n\n\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":780,"y":120,"wires":[["fcb8c4111f3bddd0"]]},{"id":"9facaba6ce550dd2","type":"mqtt in","z":"ca15b45a6a5a96ab","name":"","topic":"homeassistant/unificmd/#","qos":"2","datatype":"auto-detect","broker":"dac17249.b02d3","nl":false,"rap":true,"rh":0,"inputs":0,"x":130,"y":460,"wires":[["e4a1cdee39b0d269"]]},{"id":"e4a1cdee39b0d269","type":"function","z":"ca15b45a6a5a96ab","d":true,"name":"Block or Unblock","func":"var Topic = msg.topic\nvar TOPIC = Topic.split('/')\nvar mac = TOPIC[3]\n\nif (msg.payload == \"ON\"){\n msg.payload = {\n \"command\": \"unblockClient\",\n \"mac\": TOPIC[3]\n }\n} else {\n msg.payload = {\n \"command\": \"blockClient\",\n \"mac\": TOPIC[3]\n }\n\n}\n\nmsg.topic = \"Blocking\"\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":460,"wires":[["3366c513d01846b6"]]},{"id":"6386d006de2ba9fc","type":"function","z":"ca15b45a6a5a96ab","name":"Block and Unblock Status","func":"const a = msg.payload[0][0]\nvar stato\nif (msg.payload[0][0].blocked == true ){\n stato = \"OFF\"\n} else {\n stato = \"ON\"\n}\n\n\nmsg.topic = \"homeassistant/unifi/\" + msg.payload[0][0]._id + \"/state\"\nmsg.payload = stato\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":160,"wires":[["fcb8c4111f3bddd0"]]},{"id":"c5d257fbdebb227f","type":"inject","z":"ca15b45a6a5a96ab","name":"AccessDevices","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"120","crontab":"","once":true,"onceDelay":"5","topic":"AccessDevices","payload":"{\"command\": \"AccessDevices\"}","payloadType":"json","x":130,"y":180,"wires":[["3366c513d01846b6"]]},{"id":"6e99d5d9567aa493","type":"function","z":"ca15b45a6a5a96ab","name":"AccessDevices - Builder Dinamic","func":"const a = msg.payload\nmsg.accessdevices = a\n\na.forEach((element) => {\n // send info about state of AP\n if (typeof element.state != \"undefined\") {\n if (typeof element.name != \"undefined\") {\n var nome = element.name\n } else {\n nome = element.model\n }\n\n msg.topic = \"homeassistant/binary_sensor/ubiquiti\" + element._id + \"/config\"\n msg.payload = {\n \"name\": nome,\n \"unique_id\": \"ubiquiti\" + element._id,\n \"icon\": \"mdi:access-point\",\n \"device_class\": \"connectivity\",\n \"payload_on\": 1,\n \"payload_off\": 0,\n \"state_topic\": \"homeassistant/ubiquiti/\" + element._id + \"/state/json\",\n \"value_template\": \"{{ value_json.state }}\",\n \"json_attributes_topic\": \"homeassistant/ubiquiti/\" + element._id + \"/state/json\"\n }\n node.send(msg);\n }\n\n\n // send info connected clients\n if (typeof element.num_sta != \"undefined\") {\n msg.topic = \"homeassistant/sensor/ubiquitiusers\" + element._id + \"/config\"\n msg.payload = {\n \"name\": \"Users: \" + nome,\n \"unique_id\": \"ubiquitiusers\" + element._id,\n \"icon\": \"mdi:accpunt\",\n \"unit_of_measurement\": \"n\",\n \"state_topic\": \"homeassistant/ubiquiti/\" + element._id + \"/users/json\",\n \"value_template\": \"{{ value_json.num_sta }}\",\n \"json_attributes_topic\": \"homeassistant/ubiquiti/\" + element._id + \"/users/json\"\n }\n node.send(msg);\n }\n\n\n // AP led\n if (typeof element.led_override != \"undefined\") {\n msg.topic = \"homeassistant/light/ubiquitiled\" + element._id + \"/config\"\n msg.payload = {\n \"name\": \"Led: \" + nome,\n \"unique_id\": \"ubiquitiled\" + element._id,\n \"icon\": \"mdi:led-outline\",\n \"payload_on\": \"on\",\n \"payload_off\": \"off\",\n \"state_topic\": \"homeassistant/ubiquiti/\" + element._id + \"/led\",\n \"command_topic\": \"homeassistant/unifiapcmd/led/\" + element._id\n }\n node.send(msg);\n }\n\n\n // send info about bytes\n if (typeof element.bytes != \"undefined\") {\n msg.topic = \"homeassistant/sensor/unifibytes\" + element._id + \"/config\"\n msg.payload = {\n \"name\": \"MB: \" + nome,\n \"unique_id\": \"unifibytes\" + element._id,\n \"icon\": \"mdi:speedometer\",\n \"unit_of_measurement\": \"MB\",\n \"state_topic\": \"homeassistant/ubiquiti/\" + element._id + \"/bytes/json\",\n \"value_template\": \"{{ value_json.bytes }}\",\n \"json_attributes_topic\": \"homeassistant/ubiquiti/\" + element._id + \"/bytes/json\"\n }\n node.send(msg);\n }\n\n // send info about radio\n if (typeof element.vap_table != \"undefined\") {\n var i = 1\n element.vap_table.forEach((vap) => {\n if (typeof vap[\"radio_name\"] != \"undefined\") {\n var radionome = vap[\"radio_name\"]\n } else {\n radionome = \"\"\n }\n msg.topic = \"homeassistant/sensor/unifiradio_\" + i + element._id + \"/config\"\n msg.payload = {\n \"name\": \"Client Signal: \" + radionome,\n \"unique_id\": \"unifiradio_\" + i + element._id,\n \"icon\": \"mdi:wifi\",\n \"unit_of_measurement\": \"db\",\n \"state_topic\": \"homeassistant/ubiquiti/\" + element._id + \"/\" + vap[\"radio_name\"] + \"/info/json\",\n \"value_template\": \"{{ value_json.avg_client_signal }}\",\n \"json_attributes_topic\": \"homeassistant/ubiquiti/\" + element._id + \"/\" + vap[\"radio_name\"] + \"/info/json\"\n }\n node.send(msg);\n i = i + 1\n\n });\n }\n\n\n\n\n // send info about radio2\n if (typeof element.radio_table_stats != \"undefined\") {\n var i = 1\n element.radio_table_stats.forEach((radio) => {\n if (typeof radio[\"name\"] != \"undefined\") {\n var radionome = radio[\"name\"]\n } else {\n radionome = \"\"\n }\n\n msg.topic = \"homeassistant/sensor/unifistatus_\" + i + element._id + \"/config\"\n msg.payload = {\n \"name\": \"Radio State: \" + radionome,\n \"unique_id\": \"unifistatus_\" + i + element._id,\n \"icon\": \"mdi:wifi\",\n \"unit_of_measurement\": \"db\",\n \"state_topic\": \"homeassistant/ubiquiti/\" + element._id + \"/\" + radio[\"name\"] + \"/info/json\",\n \"value_template\": \"{{ value_json.avg_client_signal }}\",\n \"json_attributes_topic\": \"homeassistant/ubiquiti/\" + element._id + \"/\" + radio[\"name\"] + \"/state/json\"\n }\n node.send(msg);\n i = i + 1\n });\n }\n\n\n});\n\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":840,"y":200,"wires":[["52a518474c2ca6bf","fcb8c4111f3bddd0"]]},{"id":"52a518474c2ca6bf","type":"function","z":"ca15b45a6a5a96ab","name":"AccessDevices","func":"const a = msg.accessdevices\n\nvar array_ap = {}\nvar bytes_info = {}\n\nfunction secondsToString(seconds) {\n var numyears = Math.floor(seconds / 31536000);\n var numdays = Math.floor((seconds % 31536000) / 86400);\n var numhours = Math.floor(((seconds % 31536000) % 86400) / 3600);\n var numminutes = Math.floor((((seconds % 31536000) % 86400) % 3600) / 60);\n var numseconds = (((seconds % 31536000) % 86400) % 3600) % 60;\n var human = \"\"\n if (numyears>0){\n human = human + numyears + \"y \" \n }\n if (numdays > 0) {\n human = human + numdays + \"d \"\n }\n\n if (numhours > 0) {\n human = human + numhours + \"h \"\n }\n\n if (numminutes > 0) {\n human = human + numminutes + \"m \"\n }\n\n if (numseconds > 0) {\n human = human + numseconds + \"s \"\n }\n\n return human;\n\n}\n\na.forEach((element) => {\n //msg.payload = element.vap_table\n //msg.payload = element._id\n\n //master topic for send info\n var topic_radice = \"unifi/\" + element._id + \"/\"\n\n\n //send info about some data of AP\n const parametri = [\"disabled\",\"state\", \"_id\", \"model\", \"version\", \"type\", \"config_network.ip\", \"config_network.type\", \"uptime\", \"name\", \"satisfaction\", \"disabled\", \"num_sta\", \"user-num_sta\", \"user-wlan-num_sta\", \"guest-num_sta\", \"guest-wlan-num_sta\", \"system-stats\"]\n\n var info_ap = {}\n parametri.forEach((elementi) => {\n if (typeof element[elementi] != \"undefined\") {\n info_ap[elementi] = element[elementi]\n if (elementi == \"system-stats\"){\n info_ap[\"cpu\"] = element[\"system-stats\"].cpu\n info_ap[\"mem\"] = element[\"system-stats\"].mem\n }\n\n if (elementi == \"uptime\") {\n info_ap[\"uptimeU\"] = secondsToString(element[\"uptime\"])\n }\n\n\n }\n\n });\n\n\n\n\n\n\n // send info about state of AP\n if (typeof element.state != \"undefined\") {\n msg.topic = \"homeassistant/ubiquiti/\" + element._id + \"/state\"\n msg.payload = element.state\n node.send(msg)\n msg.topic = \"homeassistant/ubiquiti/\" + element._id + \"/state/json\"\n msg.payload = info_ap\n node.send(msg)\n }\n\n\n // AP led\n if (typeof element.led_override != \"undefined\") {\n msg.topic = \"homeassistant/ubiquiti/\" + element._id + \"/led\"\n msg.payload = element.led_override\n node.send(msg)\n }\n \n\n // send info connected clients\n if (typeof element.num_sta != \"undefined\") {\n msg.topic = \"homeassistant/ubiquiti/\" + element._id + \"/users\"\n msg.payload = element.num_sta\n node.send(msg)\n msg.topic = \"homeassistant/ubiquiti/\" + element._id + \"/users/json\"\n msg.payload = info_ap\n node.send(msg)\n }\n\n // send info about bytes\n if (typeof element.bytes != \"undefined\") {\n bytes_info = {}\n bytes_info[\"bytes\"] = element.bytes\n if (typeof element.tx_bytes != \"undefined\") {\n bytes_info[\"tx_bytes\"] = element.tx_bytes\n bytes_info[\"MB_tx_bytes\"] = Math.round(element.tx_bytes / 10000) / 100\n }\n\n if (typeof element.tx_bytes != \"undefined\") {\n bytes_info[\"rx_bytes\"] = element.tx_bytes\n bytes_info[\"MB_rx_bytes\"] = Math.round(element.rx_bytes / 10000) / 100\n }\n\n msg.topic = \"homeassistant/ubiquiti/\" + element._id + \"/bytes\"\n msg.payload = Math.round(element.bytes / 10000) / 100\n bytes_info[\"MB_bytes\"] = Math.round(element.bytes / 10000) / 100\n node.send(msg)\n msg.topic = \"homeassistant/ubiquiti/\" + element._id + \"/bytes/json\"\n msg.payload = bytes_info\n node.send(msg)\n }\n\n\n\n // send info about radio\n if (typeof element.vap_table != \"undefined\") {\n const parametri2 = [\"avg_client_signal\", \"bw\", \"channel\", \"satisfaction\", \"radio\", \"radio_name\"];\n element.vap_table.forEach((vap) => {\n var info_radio = {}\n parametri2.forEach((itemvap) => {\n if (typeof vap[itemvap] != \"undefined\") {\n info_radio[itemvap] = vap[itemvap]\n }\n if (itemvap == \"radio_name\") {\n msg.topic = \"homeassistant/ubiquiti/\" + element._id + \"/\" + vap[itemvap] + \"/info\"\n msg.payload = vap[\"avg_client_signal\"]\n node.send(msg)\n msg.topic = \"homeassistant/ubiquiti/\" + element._id + \"/\" + vap[itemvap] + \"/info/json\"\n msg.payload = info_radio\n node.send(msg)\n }\n });\n });\n }\n\n\n\n\n // send info about radio2\n if (typeof element.radio_table_stats != \"undefined\") {\n const parametri3 = [\"name\", \"channel\", \"satisfaction\", \"num_sta\", \"guest-num_sta\", \"user-num_sta\", \"radio\", \"state\"];\n element.radio_table_stats.forEach((radio) => {\n var info_radio2 = {}\n parametri3.forEach((itemradio) => {\n if (typeof radio[itemradio] != \"undefined\") {\n info_radio2[itemradio] = radio[itemradio]\n }\n if (itemradio == \"state\") {\n msg.topic = \"homeassistant/ubiquiti/\" + element._id + \"/\" + radio[\"name\"] + \"/state\"\n msg.payload = radio[\"state\"]\n node.send(msg)\n msg.topic = \"homeassistant/ubiquiti/\" + element._id + \"/\" + radio[\"name\"] + \"/state/json\"\n msg.payload = info_radio2\n node.send(msg)\n }\n });\n });\n }\n\n\n\n\n\n\n\n\n //node.send(msg);\n //console.log(element);\n});\n\n//return msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1180,"y":160,"wires":[["fcb8c4111f3bddd0","1ffc7d6cbf08dafc"]]},{"id":"71ac4af553d3c733","type":"mqtt in","z":"ca15b45a6a5a96ab","name":"","topic":"homeassistant/unifiapcmd/info","qos":"2","datatype":"auto-detect","broker":"dac17249.b02d3","nl":false,"rap":true,"rh":0,"inputs":0,"x":140,"y":400,"wires":[["fbe063632d457edb"]]},{"id":"fbe063632d457edb","type":"function","z":"ca15b45a6a5a96ab","name":"AccessDevices","func":" msg.payload = {\n \"command\": \"AccessDevices\"\n }\nmsg.topic = \"AccessDevices\"\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":420,"y":400,"wires":[["3366c513d01846b6"]]},{"id":"b2139d9142b197ad","type":"debug","z":"ca15b45a6a5a96ab","name":"debug 13","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":740,"y":20,"wires":[]},{"id":"4582b00e0058f4c0","type":"function","z":"ca15b45a6a5a96ab","name":"Led","func":"var Topic = msg.topic\nvar TOPIC = Topic.split('/')\nvar id = TOPIC[3]\n\nif (msg.payload == \"on\") {\n msg.payload = {\n \"command\": \"setapled\",\n \"device_id\": TOPIC[3],\n \"mode\": \"on\"\n }\n} else {\n msg.payload = {\n \"command\": \"setapled\",\n \"device_id\": TOPIC[3],\n \"mode\": \"off\"\n }\n\n}\n\nmsg.topic = \"Led\"\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":500,"wires":[["3366c513d01846b6","096e4907982047dc"]]},{"id":"096e4907982047dc","type":"debug","z":"ca15b45a6a5a96ab","name":"debug 19","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":620,"y":500,"wires":[]},{"id":"bb7cdedaf0576685","type":"mqtt in","z":"ca15b45a6a5a96ab","name":"","topic":"homeassistant/unifiapcmd/led/#","qos":"2","datatype":"auto-detect","broker":"dac17249.b02d3","nl":false,"rap":true,"rh":0,"inputs":0,"x":150,"y":500,"wires":[["4582b00e0058f4c0"]]},{"id":"e081d7ad10a31626","type":"function","z":"ca15b45a6a5a96ab","name":"Send Led Status","func":"const a = msg.payload[0]\nmsg.topic = \"homeassistant/ubiquiti/\" + msg.payload[0]._id + \"/led\"\nmsg.payload = msg.payload[0].led_override\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":780,"y":240,"wires":[["fcb8c4111f3bddd0"]]},{"id":"ea9d4502fb30ca23","type":"link out","z":"ca15b45a6a5a96ab","name":"to ask clients","mode":"link","links":["318241859f35d0e3"],"x":1225,"y":80,"wires":[]},{"id":"318241859f35d0e3","type":"link in","z":"ca15b45a6a5a96ab","name":"ask clients","links":["ea9d4502fb30ca23"],"x":65,"y":100,"wires":[["3366c513d01846b6"]]},{"id":"3b03ce0baf29792a","type":"mqtt in","z":"ca15b45a6a5a96ab","name":"","topic":"homeassistant/status","qos":"2","datatype":"auto-detect","broker":"dac17249.b02d3","nl":false,"rap":true,"rh":0,"inputs":0,"x":120,"y":300,"wires":[["c2b6df73df87529a"]]},{"id":"c2b6df73df87529a","type":"switch","z":"ca15b45a6a5a96ab","name":"Online","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"online","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":350,"y":300,"wires":[["ff6306ab802ab554"]]},{"id":"ff6306ab802ab554","type":"function","z":"ca15b45a6a5a96ab","name":"AccessDevices","func":" msg.payload = {\n \"command\": \"AccessDevices\"\n }\nmsg.topic = \"AccessDevices\"\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":300,"wires":[["337d456b88dae300","3366c513d01846b6"]]},{"id":"337d456b88dae300","type":"delay","z":"ca15b45a6a5a96ab","name":"","pauseType":"delay","timeout":"15","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":720,"y":300,"wires":[["4566303d76ec6e23"]]},{"id":"4566303d76ec6e23","type":"function","z":"ca15b45a6a5a96ab","name":"AllUsers","func":"msg.payload = {\n \"command\": \"AllUsers\"\n}\nmsg.topic = \"AllUsers\"\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":880,"y":300,"wires":[["3366c513d01846b6"]]},{"id":"a7297fd85ea37b96","type":"comment","z":"ca15b45a6a5a96ab","name":"https://flows.nodered.org/node/node-red-contrib-unifi","info":"","x":230,"y":40,"wires":[]},{"id":"05af66cd7cce372f","type":"debug","z":"ca15b45a6a5a96ab","name":"debug 24","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":810,"y":420,"wires":[]},{"id":"32195e76ae96f3c3","type":"inject","z":"ca15b45a6a5a96ab","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":240,"wires":[["c2b6df73df87529a"]]},{"id":"1ffc7d6cbf08dafc","type":"debug","z":"ca15b45a6a5a96ab","name":"debug 81","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1410,"y":180,"wires":[]},{"id":"0bbadfcf8bb33bc7","type":"unificonfig","name":"","ip":"192.168.1.123","port":"8443","site":"default","unifios":false,"ssl":false},{"id":"dac17249.b02d3","type":"mqtt-broker","name":"","broker":"192.168.1.57","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"15","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
And here the card
- theme: Backend-selected
title: Unifi
path: unifi
icon: phu:ubiquiti-ap
badges: []
cards:
- type: entities
entities:
- entity: light.led_ac_lite_soggiorno
- type: entities
entities:
- type: custom:multiple-entity-row
entity: binary_sensor.ac_lite_soggiorno
show_entity_picture: true
show_state: false
secondary_info:
attribute: uptimeU
entities:
- entity: binary_sensor.ac_lite_soggiorno
attribute: cpu
unit: '%'
attribute: mem
unit: '%'
- icon: mdi:restart
tap_action:
action: call-service
service: mqtt.publish
service_data:
topic: homeassistant/unifiapcmd/info
payload: refresh
icon: mdi:devices
show_state: false
secondary_info:
entity: binary_sensor.unifi_ac_lite_soggiorno
attribute: num_sta
unit: Clients
entities:
- entity: sensor.radio_state_wifi0
attribute: num_sta
unit: ' '
- entity: sensor.radio_state_wifi1
attribute: num_sta
unit: ' '
- type: custom:mini-graph-card
entities:
- entity: sensor.users_ac_lite_soggiorno
group: true
hours_to_show: 4
line_width: 3
points_per_hour: 15
show:
icon: false
state: false
labels: true
entity: sensor.client_signal_wifi0
icon: mdi:wifi
show_state: false
secondary_info:
unit: dB
entities:
- entity: sensor.client_signal_wifi0
attribute: satisfaction
unit: '%'
attribute: channel
unit: ''
attribute: num_sta
unit: ''
icon: mdi:wifi
show_state: false
secondary_info:
entity: sensor.client_signal_wifi1
unit: dB
entities:
- entity: sensor.client_signal_wifi1
unit: '%'
attribute: channel
unit: ''
attribute: num_sta
unit: ''
entities:
group: true
font_size: 85
hours_to_show: 24
style: |
ha-card {
border-radius: 0px;
box-shadow: none;
show:
icon: false
graph: false
state: false
extrema: true
average: true
entities:
group: true
hours_to_show: 4
line_width: 3
points_per_hour: 15
show:
icon: false
state: false
labels: true
- type: custom:auto-entities
card:
type: entities
filter:
include:
- name: Unifi:*
exclude: []
Bye
Sandro
