Hi All,
Thank you for your great work on Home Assistant.
I am trying to configure my gas fireplace within Home Assistant.
Everything works well except for the “current_temperature” value (which seems to default to 26):
This is my configuration:
climate:
- platform: generic_thermostat
unique_id: climate.fireplace
min_temp: 15
max_temp: 30
precision: 0.5
target_temp_step: 0.5
ac_mode: false
heater: input_boolean.fireplacemode
target_sensor: input_number.fireplacetargettemp
I use NodeRed to control the on/off functionality by comparing the current temperature to the target temperature. All this works fine.
Is there no way to set the “current_temperature” to the status of “sensor.sonofffireplace_si7021_temperature” so that it displays correctly in OH?
I can successfully change the 26 to something else using the Developer Tools…
Ideally, looking for some quick NodeRed function that will set the state similar to how the Developer Tools changes the state attributes.
Many thanks in advance.
Paul
