Hi folks,
I’ve implemented a flow that is obviously not working. Despite my geofence via the iOS companion app being rock solid, doors will lock and garage doors will shut while I’m at home. Essentially, my flow is ignoring my EZTimer initiation, and simply shutting things if they’re in an open/unlock state throughout the day.
Why is this not working right?
[{"id":"46f5119a.743498","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"aa2ca71d.d6db68","type":"api-current-state","z":"46f5119a.743498","name":"Karson Home?","server":"e204944a.31bc78","version":1,"outputs":2,"halt_if":"home","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"device_tracker.karsons_iphone","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":954.5714721679688,"y":294.5714416503906,"wires":[[],["1d9990cf.a4636f"]]},{"id":"a0c78676.6ac618","type":"server-state-changed","z":"46f5119a.743498","name":"Karson Location","server":"e204944a.31bc78","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"device_tracker.karsons_iphone","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":679.5714416503906,"y":194.35479736328125,"wires":[["aa2ca71d.d6db68"]]},{"id":"a423502f.a60a2","type":"api-call-service","z":"46f5119a.743498","name":"Lock Front Door","server":"e204944a.31bc78","version":1,"debugenabled":false,"service_domain":"lock","service":"lock","entityId":"lock.front_door_schlage_allegion_be469zp_connect_smart_deadbolt_locked","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1586.2857856750488,"y":510.0000057220459,"wires":[[]]},{"id":"bf3df078.d6e8","type":"api-call-service","z":"46f5119a.743498","name":"Close Main Garage Door","server":"e204944a.31bc78","version":1,"debugenabled":false,"service_domain":"cover","service":"close_cover","entityId":"cover.main_stall_garage_door","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1616.2857856750488,"y":190.0000057220459,"wires":[[]]},{"id":"3fae4c6.42fa4b4","type":"api-call-service","z":"46f5119a.743498","name":"Close 3rd Stall Garage Door","server":"e204944a.31bc78","version":1,"debugenabled":false,"service_domain":"cover","service":"close_cover","entityId":"cover.3rd_stall_garage_door","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1626.2857856750488,"y":310.0000057220459,"wires":[[]]},{"id":"7ff1da0d.d31a5c","type":"api-call-service","z":"46f5119a.743498","name":"Lock Back Door","server":"e204944a.31bc78","version":1,"debugenabled":false,"service_domain":"lock","service":"lock","entityId":"lock.back_door_schlage_allegion_be469zp_connect_smart_deadbolt_locked","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1586.2857856750488,"y":410.0000057220459,"wires":[[]]},{"id":"1d9990cf.a4636f","type":"switch","z":"46f5119a.743498","name":"Motion or No Motion?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1254.8572387695312,"y":297.1428909301758,"wires":[[],["bf3df078.d6e8","3fae4c6.42fa4b4","7ff1da0d.d31a5c","a423502f.a60a2"]]},{"id":"63587b8c.823a9c","type":"switch","z":"46f5119a.743498","name":"Execute Flow","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":376.0000991821289,"y":288.8572292327881,"wires":[["aa2ca71d.d6db68"]]},{"id":"dc57768e.48c498","type":"server-state-changed","z":"46f5119a.743498","name":"Kitchen Motion Sensor","server":"e204944a.31bc78","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.kitchen_ecolink_motion_detector_sensor","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"x":1049.1429595947266,"y":186.14290618896484,"wires":[["1d9990cf.a4636f"]]},{"id":"7368526b.37754c","type":"eztimer","z":"46f5119a.743498","name":"10PM","autoname":"22:00","suspended":false,"sendEventsOnSuspend":false,"lat":"42.034534","lon":"-93.620369","timerType":"2","startupMessage":false,"ontype":"2","ontimesun":"dawn","ontimetod":"22:00","onproperty":"payload","onvaluetype":"num","onvalue":1,"onoffset":0,"onrandomoffset":0,"offtype":"1","offtimesun":"dusk","offtimetod":"dusk","offduration":0,"offproperty":"payload","offvaluetype":"num","offvalue":0,"offoffset":0,"offrandomoffset":0,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"sun":true,"x":160.28582000732422,"y":289.14295291900635,"wires":[["63587b8c.823a9c"]]},{"id":"e204944a.31bc78","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
