Hello, I have multiple binary_sensors that keep triggering erroneously in NodeRED.
They are window/doors. When opening, I can see only the sensor opened in HASS. However, as I open more, all of the sensors that were previously opened are being triggered again but only in NodeRed. Example: I open my window. NodeRED node is triggered and I see the sensor opened in HA. I close the window and open the door. I see in HA that the window is closed and the door is now opened, BUT both the door and window have triggered again in NodeRED. This persists across restarts of HA and NodeRED.
By now if I open any one binary_sensor, ALL binary_sensor nodes are triggered in NodeRED.
Here’s the nodered flow:
[{"id":"f4009a0e.471a48","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"6cf257ef.2dd7f8","type":"server-state-changed","z":"f4009a0e.471a48","name":"Dining Rm Window Status","server":"d3adfccb.fd313","entityidfilter":"binary_sensor.dining_room_window","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"","halt_if_compare":"is","outputs":1,"x":230,"y":320,"wires":[[]]},{"id":"53c6c397.14bd5c","type":"server-state-changed","z":"f4009a0e.471a48","name":"Living Rm Window Status","server":"d3adfccb.fd313","entityidfilter":"binary_sensor.living_room_window","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"","halt_if_compare":"is","outputs":1,"x":230,"y":280,"wires":[[]]},{"id":"a95ec92d.2b26e8","type":"server-state-changed","z":"f4009a0e.471a48","name":"Nursery Rm Window Status","server":"d3adfccb.fd313","entityidfilter":"binary_sensor.nursery_window","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"","halt_if_compare":"is","outputs":1,"x":220,"y":240,"wires":[[]]},{"id":"7b255903.ff3858","type":"server-state-changed","z":"f4009a0e.471a48","name":"Master Bedrm Window Status","server":"d3adfccb.fd313","entityidfilter":"binary_sensor.master_bedroom_window","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"","halt_if_compare":"is","outputs":1,"x":220,"y":200,"wires":[[]]},{"id":"55fcbd0f.b88b44","type":"server-state-changed","z":"f4009a0e.471a48","name":"Main Entry Door Status","server":"d3adfccb.fd313","entityidfilter":"binary_sensor.main_entry_door","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"","halt_if_compare":"is","outputs":1,"x":240,"y":360,"wires":[[]]},{"id":"9487d375.27b83","type":"server-state-changed","z":"f4009a0e.471a48","name":"Garage Entry Door Status","server":"d3adfccb.fd313","entityidfilter":"binary_sensor.garage_entry_door","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"","halt_if_compare":"is","outputs":1,"x":230,"y":400,"wires":[[]]},{"id":"e45ea84a.66eea8","type":"server-state-changed","z":"f4009a0e.471a48","name":"Garage Overhead Door Status","server":"d3adfccb.fd313","entityidfilter":"binary_sensor.garage_overhead_door","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"","halt_if_compare":"is","outputs":1,"x":220,"y":440,"wires":[[]]},{"id":"d3adfccb.fd313","type":"server","z":"","name":"Home Assistant"}]
