Recently, nodered has been failing to start in my HA. I am unsure of when this became an issue so cannot trace it back to a specific update.
I have had a few flows which were flows imported from forums for use in later Flow projects so I know that some of thesesl would not be correctly set up for my system (other people’s device names etc).
However, I managed to disable those identified in Safe Mode so thought it would now be OK. However after the most recent HA upgrade and hence a restart, still failing to start. Logs are below:
14 Jul 01:58:45 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:58:45 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:58:50 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:58:50 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:58:55 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:58:55 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:00 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:59:00 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:05 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:59:05 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:10 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:59:10 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:15 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:59:15 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:20 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:59:20 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:25 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:59:25 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:30 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:30 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:59:35 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:35 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:59:43 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:43 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:59:48 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:48 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:59:53 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:53 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 01:59:58 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 01:59:58 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:03 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:00:03 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:08 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:00:08 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:13 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:00:13 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:18 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:00:18 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:23 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:00:23 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:28 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:00:28 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:33 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:00:33 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:38 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:00:38 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:43 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:00:43 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:48 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:00:48 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:53 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:00:54 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:00:58 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:01:00 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:01:04 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:01:07 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:01:09 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:01:12 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:01:14 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:01:17 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:01:19 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:01:22 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:01:24 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:01:27 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:01:29 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:01:32 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:01:34 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:01:37 - [info] [server:Home assistant] Connecting to http://supervisor/core
14 Jul 02:01:39 - [info] [server:Home assistant] Connected to http://supervisor/core
14 Jul 02:01:39 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jul 02:01:41 - [info] [server:Home Assistant] Connected to http://supervisor/core
14 Jul 02:02:17 - [info] [server:Home assistant] Connection closed to http://supervisor/core
14 Jul 02:02:17 - [red] Uncaught Exception:
14 Jul 02:02:17 - [error] UnhandledPromiseRejection: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason "#<Object>".
[02:02:17] INFO: Service Node-RED exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[02:02:18] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped```
