I just begin my test of home assistant and for automatisation I used nodered. But I have an issue with nodered, it restart himself about every hour (sometime more). I don’t understand why I try to remove it (with deletion of nodered folder) and readd it same error :
22 May 15:00:43 - [error] Error: Invalid context key
at Object.value (/opt/node_modules/@node-red/runtime/lib/nodes/context/index.js:291:31)
at EventsState.getContextValue (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:143:34)
at EventsState.getComparatorResult (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:167:27)
at EventsState.onHaEventsStateChanged (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/events-state/controller.js:71:32)
at EventEmitter.emit (node:events:538:35)
at Websocket.emitEvent (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/homeAssistant/Websocket.js:35:30)
at Websocket.onClientEvents (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/homeAssistant/Websocket.js:257:22)
at Object.callback (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/homeAssistant/Websocket.js:188:65)
at WebSocket.Connection._handleMessage (/opt/node_modules/home-assistant-js-websocket/dist/haws.cjs:174:30)
at WebSocket.onMessage (/opt/node_modules/node-red-contrib-home-assistant-websocket/node_modules/ws/lib/event-target.js:199:18)
I don’t find why, can someone already see that ? How can I fix that ? It’s anoying because I have some flow that wait 30/40min before do an action and it’s fail when nodered restart.
Thank in advance
