After some updates (i guess the homeassistant nodes) in Nodered, i got following error:
“HomeAssistantError: must contain at least one of entity_id, device_id, area_id, floor_id, label_id.”
This is caused by the update from the call-service node to the action node. so far so good.
My problem is that I used this to change the Hvac_mode (from off to auto) and with the old call_service node, this was pretty straight forward. With the action node I do not manage to get this up and running. There is still the set.hvac_mode, but I don’t manage to get an entity attached to it. I also tried some other things with no luck.
Could someone please give my a clear explantion what steps I should take - preferrably with an example.
Thanks in advance - my wife will be happy when the heating is working again ![]()
My apologies if I didn(t find the answer in the forum yet.
