I am using Hassio 0.78.0
I am using esphomeyaml (installed via the community addon) to create sensors, and letting MQTT discovery automatically create new entities within Home Assistant.
I also have NodeRed installed (via the community addon). However, the only entity IDs that show up in NodeRed are those that have been manually created via the Home Assistant configuration.yaml file. None of the entities created automatically via MQTT discovery show up.
Is this the norm, or is there a way around this?
Apologies if this has been covered before.I have searched, but not found anything.
