Nodes not showing in Home Assistant GUI?
In the Z-wave control center in Hass.io I only see the hub, which is the AEON Labs ZW090 Z-Stick Gen5.
The OZW_log.txt, however seems to be normal…
Where can I start lokking for errors?
19-09-17 19:42:22.603 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=1102.5W
2019-09-17 19:42:22.603 Detail, Node002, Refreshed Value: old value=776.6, new value=1102.5, type=decimal
2019-09-17 19:42:22.603 Detail, Node002, Changes to this value are not verified
2019-09-17 19:42:22.603 Detail, Node002, Notification: ValueChanged
2019-09-17 19:42:23.583 Detail, Node006,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x06, 0x0e, 0x32, 0x02, 0x21, 0x74, 0x00, 0x29, 0xa6, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x12
2019-09-17 19:42:23.584 Detail,
2019-09-17 19:42:23.584 Detail, Node006, Refreshed Value: old value=false, new value=false, type=bool
2019-09-17 19:42:23.584 Detail, Node006, Changes to this value are not verified
2019-09-17 19:42:23.584 Info, Node006, Received Meter report from node 6: Power=2729.503W
2019-09-17 19:42:23.584 Detail, Node006, Refreshed Value: old value=2664.222, new value=2729.503, type=decimal
2019-09-17 19:42:23.585 Detail, Node006, Notification: ValueChanged
2019-09-17 19:42:23.592 Detail, Node006, Notification: ValueChanged
2019-09-17 19:42:34.607 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x01, 0x38, 0xd8
2019-09-17 19:42:34.607 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=31.2W
2019-09-17 19:42:34.607 Detail, Node002, Refreshed Value: old value=1102.5, new value=31.2, type=decimal
2019-09-17 19:42:34.607 Detail, Node002, Changes to this value are not verified
2019-09-17 19:42:34.607 Detail, Node002, Notification: ValueChanged
2019-09-17 19:42:35.625 Detail, Node002,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x10, 0xf1
2019-09-17 19:42:35.626 Detail,
2019-09-17 19:42:35.626 Info, Node002, Received SensorMultiLevel report from node 2, instance 1, Power: value=1.6W
2019-09-17 19:42:35.626 Detail, Node002, Refreshed Value: old value=31.2, new value=1.6, type=decimal
2019-09-17 19:42:35.626 Detail, Node002, Changes to this value are not verified
2019-09-17 19:42:35.626 Detail, Node002, Notification: ValueChanged
2019-09-17 19:42:44.725 Detail, Node021,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x15, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x1f, 0xe9
2019-09-17 19:42:44.725 Info, Node021, Received SensorMultiLevel report from node 21, instance 1, Power: value=3.1W
2019-09-17 19:42:44.725 Detail, Node021, Refreshed Value: old value=3.2, new value=3.1, type=decimal
2019-09-17 19:42:44.725 Detail, Node021, Changes to this value are not verified
2019-09-17 19:42:44.725 Detail, Node021, Notification: ValueChanged
2019-09-17 19:42:50.280 Detail, Node027, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2019-09-17 19:42:50.280 Detail, Node027, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_SENSOR_MULTILEVEL
2019-09-17 19:42:50.281 Detail, Node027, Queuing (Poll) SensorMultilevelCmd_Get (Node=27): 0x01, 0x0a, 0x00, 0x13, 0x1b, 0x03, 0x31, 0x04, 0x01, 0x25, 0x62, 0x8d
2019-09-17 19:42:50.281 Info, Node027, Processing (Poll) Nonce Request message (Callback ID=0x62, Expected Reply=0x04)
2019-09-17 19:42:50.281 Info, Node027, Sending (Poll) message (Callback ID=0x62, Expected Reply=0x04) - Nonce_Get(SensorMultilevelCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x1b, 0x02, 0x98, 0x40, 0x05, 0x02:
2019-09-17 19:42:50.298 Detail, Node027,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-09-17 19:42:50.298 Detail, Node027,   ZW_SEND_DATA delivered to Z-Wave stack
2019-09-17 19:42:50.320 Detail, Node027,   Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0xeb
2019-09-17 19:42:50.320 Detail, Node027,   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2019-09-17 19:42:50.320 Info, Node027, Request RTT 39 Average Request RTT 77
2019-09-17 19:42:50.341 Detail, Node027,   Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x1b, 0x0a, 0x98, 0x80, 0x5f, 0x56, 0x50, 0xb4, 0xd5, 0x3e, 0x34, 0x43, 0x93
2019-09-17 19:42:50.341 Info, Node027, Received SecurityCmd_NonceReport from node 27
2019-09-17 19:42:50.341 Info, Node027, Sending (Poll) message (Callback ID=0x63, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=27): 0x01, 0x0a, 0x00, 0x13, 0x1b, 0x03, 0x31, 0x04, 0x01, 0x25, 0x63, 0x8c
2019-09-17 19:42:50.354 Detail, Node027,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-09-17 19:42:50.354 Detail, Node027,   ZW_SEND_DATA delivered to Z-Wave stack
2019-09-17 19:42:50.381 Detail, Node027,   Received: 0x01, 0x07, 0x00, 0x13, 0x63, 0x00, 0x00, 0x03, 0x8b
2019-09-17 19:42:50.381 Detail, Node027,   ZW_SEND_DATA Request with callback ID 0x63 received (expected 0x63)
2019-09-17 19:42:50.381 Info, Node027, Request RTT 99 Average Request RTT 88
2019-09-17 19:42:50.381 Detail,   Expected callbackId was received
2019-09-17 19:42:50.402 Detail, Node027,   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x1b, 0x02, 0x98, 0x40, 0x32
2019-09-17 19:42:50.403 Info, Node027, Received SecurityCmd_NonceGet from node 27
2019-09-17 19:42:50.403 Info, NONCES: 0xc3, 0xd4, 0x0a, 0x28, 0xaf, 0x45, 0x64, 0xb2
2019-09-17 19:42:50.403 Info, NONCES: 0x08, 0x5f, 0xa1, 0xc8, 0xbb, 0x51, 0x8b, 0x8a
2019-09-17 19:42:50.403 Info, NONCES: 0x48, 0xfd, 0x02, 0xdb, 0x17, 0x6f, 0x4a, 0xeb
2019-09-17 19:42:50.403 Info, NONCES: 0x81, 0xf5, 0xd8, 0x33, 0xd4, 0xcc, 0xea, 0x9c
2019-09-17 19:42:50.403 Info, NONCES: 0xbc, 0x4a, 0x8c, 0x0b, 0xc2, 0x9d, 0x6b, 0x32
2019-09-17 19:42:50.403 Info, NONCES: 0xc8, 0xb4, 0xc5, 0x25, 0x58, 0x9d, 0x36, 0xa1
2019-09-17 19:42:50.403 Info, NONCES: 0x24, 0xfe, 0x83, 0x54, 0xe8, 0x34, 0xaa, 0xfe
2019-09-17 19:42:50.403 Info, NONCES: 0xa1, 0xcc, 0x83, 0xee, 0x69, 0x82, 0xe0, 0x15
2019-09-17 19:42:50.405 Info, Node027, Sending (Poll) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x1b, 0x0a, 0x98, 0x80, 0x81, 0xf5, 0xd8, 0x33, 0xd4, 0xcc, 0xea, 0x9c, 0x05, 0x01, 0x01:
2019-09-17 19:42:50.415 Detail, Node027,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-09-17 19:42:50.415 Detail, Node027,   ZW_SEND_DATA delivered to Z-Wave stack
2019-09-17 19:42:50.437 Detail, Node027,   Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x03, 0xe9
2019-09-17 19:42:50.437 Detail, Node027,   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2019-09-17 19:42:50.437 Info, Node027, Request RTT 155 Average Request RTT 121
2019-09-17 19:42:50.467 Detail, Node027,   Received: 0x01, 0x20, 0x00, 0x04, 0x00, 0x1b, 0x1a, 0x98, 0x81, 0x02, 0xbd, 0x73, 0xee, 0x10, 0x80, 0x05, 0xb6, 0x76, 0x8f, 0xa0, 0xe8, 0x29, 0x5a, 0x7f, 0x81, 0x5b, 0x01, 0x0c, 0xd8, 0xc5, 0x67, 0x78, 0xa1, 0x0b
2019-09-17 19:42:50.467 Info, Raw: 0x98, 0x81, 0x02, 0xbd, 0x73, 0xee, 0x10, 0x80, 0x05, 0xb6, 0x76, 0x8f, 0xa0, 0xe8, 0x29, 0x5a, 0x7f, 0x81, 0x5b, 0x01, 0x0c, 0xd8, 0xc5, 0x67, 0x78, 0xa1, 0x0b
2019-09-17 19:42:50.468 Detail, Node027, Decrypted Packet: 0x00, 0x31, 0x05, 0x01, 0x22, 0x00, 0xf4
2019-09-17 19:42:50.468 Info, Node027, Response RTT 186 Average Response RTT 183
2019-09-17 19:42:50.468 Info, Node027, Received SensorMultiLevel report from node 27, instance 1, Temperature: value=24.4C
2019-09-17 19:42:50.468 Detail, Node027, Refreshed Value: old value=24.4, new value=24.4, type=decimal
2019-09-17 19:42:50.468 Detail, Node027, Changes to this value are not verified
2019-09-17 19:42:50.468 Detail, Node027,   Expected reply and command class was received
2019-09-17 19:42:50.468 Detail, Node027,   Message transaction complete
2019-09-17 19:42:50.468 Detail, Node027, Removing current message
2019-09-17 19:42:50.469 Detail, Node027, Notification: ValueChanged
Here is the start of the log after boot
2019-09-17 19:17:26.540 Always, OpenZwave Version 1.4.3440 Starting Up
2019-09-17 19:17:38.850 Info, Setting Up Provided Network Key for Secure Communications
2019-09-17 19:17:38.850 Info, mgr,     Added driver for controller /dev/ttyACM0
2019-09-17 19:17:38.856 Info,   Opening controller /dev/ttyACM0
2019-09-17 19:17:38.856 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2019-09-17 19:17:38.874 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2019-09-17 19:17:38.874 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-09-17 19:17:38.874 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-09-17 19:17:38.874 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-09-17 19:17:38.874 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-09-17 19:17:38.874 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-09-17 19:17:38.874 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-09-17 19:17:38.882 Detail, contrlr,   Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x35, 0x34, 0x00, 0x01, 0x93
2019-09-17 19:17:38.882 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2019-09-17 19:17:38.882 Info, contrlr,     Static Controller library, version Z-Wave 4.54
2019-09-17 19:17:38.882 Detail, Node045,   Expected reply was received
2019-09-17 19:17:38.882 Detail, Node045,   Message transaction complete
2019-09-17 19:17:38.882 Detail, contrlr, Removing current message
2019-09-17 19:17:38.882 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-09-17 19:17:38.888 Detail, contrlr,   Received: 0x01, 0x08, 0x01, 0x20, 0xe1, 0x95, 0xd6, 0xdb, 0x01, 0xae
2019-09-17 19:17:38.888 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xe195d6db.  Our node ID = 1
2019-09-17 19:17:38.888 Detail, Node149,   Expected reply was received
2019-09-17 19:17:38.888 Detail, Node149,   Message transaction complete
2019-09-17 19:17:38.888 Detail, contrlr, Removing current message
2019-09-17 19:17:38.888 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-09-17 19:17:38.892 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x05, 0x08, 0xf7
2019-09-17 19:17:38.892 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2019-09-17 19:17:38.892 Info, contrlr,     There is no SUC ID Server (SIS) in this network.
2019-09-17 19:17:38.892 Info, contrlr,     The PC controller is a primary controller.
2019-09-17 19:17:38.892 Detail, Node247,   Expected reply was received
2019-09-17 19:17:38.892 Detail, Node247,   Message transaction complete
2019-09-17 19:17:38.892 Detail, contrlr, Removing current message
2019-09-17 19:17:38.892 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-09-17 19:17:38.899 Detail, contrlr,   Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x01, 0x00, 0x86, 0x00, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfa
2019-09-17 19:17:38.899 Info, contrlr,  Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2019-09-17 19:17:38.899 Info, contrlr,     Serial API Version:   1.1
2019-09-17 19:17:38.899 Info, contrlr,     Manufacturer ID:      0x0086
2019-09-17 19:17:38.899 Info, contrlr,     Product Type:         0x0001
2019-09-17 19:17:38.899 Info, contrlr,     Product ID:           0x005a
2019-09-17 19:17:38.899 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2019-09-17 19:17:38.899 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2019-09-17 19:17:38.899 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2019-09-17 19:17:38.900 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2019-09-17 19:17:38.900 Detail, Node001,   Expected reply was received
Try restarting Home Assistant.
I have restarted HA several times.
And even restarted the host OS.
I have started a heal network process one hour ago and still no progress
The nodes are clearly paired, what does your Home Assistant log show?
I noticed I have the service garbage_collection in my configuration, which the log showed is not tested for my version of Home Assistant.
I removed this config, and now the node list populates in the GUI.
All wired nodes seem to show up OK, but those running om battery do not show. Maybe because the are sleeping, and will be connected when they wake up?
home-assistant.log
2019-09-17 22:45:08 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-09-17 22:45:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.template
2019-09-17 22:45:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.systemmonitor
2019-09-17 22:45:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.nordpool
2019-09-17 22:45:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.google_geocode
2019-09-17 22:45:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.version
2019-09-17 22:45:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.time_date
2019-09-17 22:45:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.garbage_collection
2019-09-17 22:45:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.yr
2019-09-17 22:45:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rest
2019-09-17 22:45:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.command_line
2019-09-17 22:45:15 ERROR (SyncWorker_2) [homeassistant.components.command_line.sensor] Command failed: bash /config/scripts/check-weather-buskogen.sh
2019-09-17 22:45:17 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.zwave
2019-09-17 22:45:17 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.esphome
2019-09-17 22:45:17 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mqtt
2019-09-17 22:45:17 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mobile_app
2019-09-17 22:45:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.utility_meter
2019-09-17 22:45:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.verisure
2019-09-17 22:45:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.tibber
2019-09-17 22:45:19 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy
  File "/usr/src/homeassistant/homeassistant/components/device_tracker/setup.py", line 77, in async_setup_legacy
    discovery_info,
  File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 97, in setup_scanner
    for dev in discover_devices():
  File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 72, in discover_devices
    device_id=device_id,
  File "/usr/local/lib/python3.7/site-packages/bluetooth/bluez.py", line 26, in discover_devices
    device_id = _bt.hci_get_route()
OSError: [Errno 97] Address family not supported by protocol
2019-09-17 22:45:20 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hacs
2019-09-17 22:45:23 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.ios
Correct they will wake up and report in on their interval, best to just wait on those rather than mess with them. Good to hear you figured out the issue.
[quote=“firstof9, post:7, topic:137740”]
Correct they will wake up and report in on their interval, best to just wait on those rather than mess with them. [/quote]
… which make me look for a solution where restarting Home Assistant don’t force reloading all zwave nodes. I have heard other users having the zwave stick connected to a separate unit that is not rebooted, and all zwave units are in place most of the time regardless of ha
Any pros/cons on that?
I’d say personal preference, letting the node check in on it’s own isn’t going to hurt anything. The sensor will still update if there’s a change.
I personally don’t see a point to have a “dedicated zwave” Pi or similar.
