NODO RFLink Pro module: First time setup
I got a Nodo RFLink Pro set with a ESP32-C3 module (which acts as wifi-serial bridge as I learned).
However, it came with zero documentation. The only thing I see, that the ESP32-C3 has some kind of luatos installed on it.
I thought I cant setup ESPLink on it, but it seems, that ESPLink is not meant for ESP32?
What is the state of the art to setup an ESP32-C3 Super Mini as serial bridge?
Thanks in advance!
Okay, I found that ESPEasy with an Serial server can be a way. The serial server has a mode for RFLink:
https://espeasy.readthedocs.io/en/latest/Plugin/P020.html
Need to test it.
Did you get this working?
Yes. It was working this way. However, The RFLink was not working for my case, so I sold it. But ESPEasy with that module was working!
