Nodon Octan Remote (How to)
I’m using the QT OpenZWave beta + Mosquitto add-ons, but they don’t seem to create entities that will work in these automations. For the entities I get:
sensor.crc_3_6_0x_soft_remote_basic
sensor.crc_3_6_0x_soft_remote_basic_duration
sensor.crc_3_6_0x_soft_remote_basic_target
sensor.crc_3_6_0x_soft_remote_battery_level
I realise that the battery level sensor is not relevant for this automation, but none of the others will work either. I’m seeing the scene_id in the OpenZWave log (10, 20, 30, 40 for the buttons 1, 2, 3, 4 respectively), but it doesn’t seem to be associated with any of the known entities.
Does anyone have any idea on what I’m doing wrong? Thanks.
You need to switch your node configuration from Central Scene to Scene Activation :
I already did change to Scene Activation - no difference.
When you do this, It do not create any additional entities but trigger ozw.scene_activated events.
OK, thanks, I’ll keep trying this. I’m new to HA (been using Domoticz for years), and still finding (groping) my way around…
I am seeing the scene_id events in the ozw log, but not clear how to connect these up with scenes in HA…
I’m using NodeRed to manage my automation but if you use HA automation it must look something like this (based from exemple seen before) :
- alias: Bryter Toalett Overetasjen På
    platform: event
    event_type: ozw.scene_activated
    event_data:
      entity_id: zwave.bryter_toalett_overetasje
      scene_id: 10
    - service: light.turn_on
      entity_id: light.dimmer_toalett_overetasje_level
Well, I tried something like that:
alias: Button 1 pressed
description: ''
  - platform: event
    event_type: zwave.scene_activated
    event_data:
      entity_id: sensor.crc_3_6_0x_soft_remote_battery_level
      scene_id: 10
condition: []
  - type: turn_on
    device_id: fffa7d1113c111eba1553948e862da35
    entity_id: switch.fgwpe_f_wall_plug_switch_2
    domain: switch
mode: single
Looking at that code, a couple of things now strike me.
  1. I used zwave.scene_activated as the event type - but is this for the older zwave integration? I’m using the OpenZwave (Beta) + MQTT - so is there another id namespace that I should be using?
  2. I tried all the entity ids for the remote, with no difference - nothing worked.
You’re right, your problem is the event_type.
In the “Old” Zwave integration, it trigger zwave.scene_activated but the “new” one trigger ozw.scene_activated.
I’m not sure about the event_data/entity_id … but battery entity seem strange.
Thanks again. I’ll play around with this further…
I think it must be something like this :
      event_data:
        node_id: 38
        scene_id: 2
It’s very odd…
Button 1 on the remote (node_id: 46) sends a scene_id of 10, while button 3 sends a scene_id of 30.
So I have two automations set up:
description: ''
  - platform: event
    event_data:
      node_id: 46
      scene_id: 1
condition: []
  - type: turn_on
    domain: switch
mode: single
alias: Button 3 pressed
description: ''
  - platform: event
    event_data:
      node_id: 46
      scene_id: 30
condition: []
  - type: turn_off
    domain: switch
mode: single
Now, I would have expected the Button 1 automation to have a scene_id of 10 (since that is what I see in the ozw log), yet it has to be set to 1 as shown for the button press to work.
And I’ve tried different values for the Button 3 automation, e.g. 2, 3, ‘30’, 30, but nothing seems to work when I press button 3…
So I’m stumped again…
Try with scene_value_id, for button 1 :
    event_data:
      node_id: 46
      scene_value_id : 10
Yay! That works using scene_value_id instead of scene_id with 10 for Button 1 and 30 for Button 3. Thank you!
I’m new to Home Assistant also so happy to have helped
