I am trying to use a NODON SIN-4-RS-20 Zigbee roller shutter micro module that I have recently installed as a test on one of my wired roller shutters.
The module is detected successfuly by the Zigbee coordinator (SkyConnect USB key) and I can see the device in the network map:
It is also present in the Zigbee devices list:
However when I pres the up or down arrows to open or close the shutter nothing happens.
I’ve double (tripled) checked my wiring and compared it to the installation diagram and everything seems ok:
It’s also worth noting that nothing happens when I press the buttons of the physical switch but this time I can hear the relay clicking.
I have searched the logs and can see the following exception each time I press the up/down buttons on the cover card:
2024-05-28 15:57:28.792 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547451069248] Unexpected exception
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 64, in wrap_zigpy_exceptions
yield
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 84, in wrapper
return await RETRYABLE_REQUEST_DECORATOR(func)(*args, **kwargs)
File "/usr/local/lib/python3.12/site-packages/zigpy/util.py", line 131, in retry
return await func()
File "/usr/local/lib/python3.12/site-packages/zigpy/zcl/__init__.py", line 377, in request
return await self._endpoint.request(
File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 265, in request
return await self.device.request(
File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 339, in request
await send_request()
File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 841, in request
await self.send_packet(
File "/usr/local/lib/python3.12/site-packages/bellows/zigbee/application.py", line 931, in send_packet
raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 239, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2738, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2779, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 975, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1047, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/zha/cover.py", line 273, in async_open_cover
res = await self._cover_cluster_handler.up_open()
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 83, in wrapper
with wrap_zigpy_exceptions():
File "/usr/local/lib/python3.12/contextlib.py", line 158, in __exit__
self.gen.throw(value)
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 75, in wrap_zigpy_exceptions
raise HomeAssistantError(message) from exc
homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
I don’t know where to look or how I can investigate this further… any help would be greatly appreciated
